Disable PATS system? - Ford Truck Enthusiasts Forums
Old 06-24-2012, 12:24 AM
blucoondawg blucoondawg is offline
blucoondawg is starting off with a positive reputation.
Hi everyone, I am new here, I have a 99 F150 XL v6 4x4 5spd manual, pretty basic truck. I seem to have lost my keyring which contained my only ignition key, I have 2 spares which will only unlock the door and turn over the engine but it will not run, one of these spares is a Ford key, I find it odd that they would give out a key which doesn't operate the ignition, anyways since I now have no way to start my truck I was wondering if there is a way to disable the PATS system completely, my truck is an old beater I am not worried about anyone stealing it, I think PATS is a racket designed to make people pay through the nose for spare keys. Sorry if this info has already been discussed I did a quick search and didn't see anything helpful. Thanks.
Old 06-24-2012, 01:09 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Ford can supply 2 styles of keys. One with and one without the transponder for the PATS. Your second key may be a transponder style but may not have been programmed. You'll need to go to Ford for new transponder loaded keys to be programmed to your vehicle as I believe two are needed even if more keys are later required to be programmed.
As for disabling, I know of none, someone might. Even if you buy a bypass module, for say a remote start, you need a matched key to program the bypass module as far as I know.
PATS- How will it affect my build? Psyclopse Excursion - King of SUVs 3 03-14-2016 11:29 AM
PATS Key Programming with Auto Enginuity 73fan 1999 to 2016 Super Duty 0 02-24-2016 07:41 PM
Disable PATS for TS 6-Position Chip BeachEx Excursion - King of SUVs 14 05-21-2014 06:29 AM
04 F250 No Pats Key christaylor 1999 to 2016 Super Duty 11 12-28-2013 11:07 AM
I have a crazy idea that might just work.. Dorito 1999 to 2016 Super Duty 8 03-13-2013 09:39 PM
Tags
bypass, disable, f150, ford, module, pats, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
