stock peddle with hydraulic clutch? can it be done?
hey all I was wondering if any of you guys have set our trucks up with a hydraulic clutch? I'm building a 390 and want to put a t5 behind it and am having a problem figuring out how to keep my stock peddle with the new trans. thanks for your help!!
I used hanging pedals with my T-56. The PO had used the original 56 brake MC as the clutch MC (they had installed a new dual circuit brake MC with the disk front brakes). Since it was leaking I bought a new clutch MC that matched my transmission and clutch slave cylinder donor (92 Camaro) and used the same hose connection fittings, (inexpensive since it is molded plastic) and built a mount for it. It has a plastic remote reservoir So it would make servicing easy on your truck if it was mounted under the same floor inspection cover as the brakes.
1956_F100
04-28-2016 11:51 AM
carpenter547
13
01-01-2010 04:36 PM
4wydnr
04-16-2009 07:24 PM
sancochojoe
05-11-2005 10:55 AM
