Quick connect fuel line ???? - Ford Truck Enthusiasts Forums
Old 06-23-2012, 08:30 PM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
Can the QCF with the inner springs be substituted for the QCf with the clips?
Old 06-23-2012, 10:08 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
If the fittings are the same size [meaning they accept the same size line] then it shouldn't be a problem.
Old 06-24-2012, 10:27 PM
Thats what i was assuming but wasn't sure,i need to replace the original stainless lines
due to trying to remove the lines and pulling out the seals.
Old 06-25-2012, 02:23 AM
WhitefishBoy64 WhitefishBoy64 is offline
WhitefishBoy64 is starting off with a positive reputation.
Howdy,
I bought a 94 frame for my project and am now in the process of adapting the body mounts. i need to remove the fuel filter and a few of the lines to allow me to use my torch and welder, how the heck do i separate these things? i have never messed with fuel lines like these before
Thanks,
WhitefishBoy64
Old 06-25-2012, 07:23 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Did you pull out the seals or the fingered retaining clips? The clips can be replaced.
Quote:
Originally Posted by WhitefishBoy64 View Post
Howdy, I bought a 94 frame for my project and am now in the process of adapting the body mounts. i need to remove the fuel filter and a few of the lines to allow me to use my torch and welder, how the heck do i separate these things? i have never messed with fuel lines like these before
Thanks, WhitefishBoy64
Buy/use these:
They release the clips shown above. Spray out the connection with brake clean, blow it out with compressed air, shoot in some spray lube/penetrant and they'll come apart with much less effort.
Old 06-25-2012, 12:02 PM
ErinsFord ErinsFord is offline
ErinsFord is starting off with a positive reputation.
Howdy,
With much cursing and frustration. Also, any auto parts store should have a Ford 'quick' disconnect tool. They're small and the bane of my existence. Took me like two hours of yelling at my truck to get them off. Good luck.
Old 06-25-2012, 01:14 PM
ncranchero's Avatar
And all this time .......... yelling at it could have made it easier!
Old 06-25-2012, 06:12 PM
I pulled out everything the clip,the seal and the line that was rusted inside(the reason for the intense pulling. i want to just scrap the original lines and use the qcf with the clips along with some nylon line.
Old 06-25-2012, 06:20 PM
But now that i think about it maybe i can get the old line remove i could just buy new clips,where do you get these clips? Dorman?
Do they sell the inner seal assembly as well? Are the fingererd clips remove just by prying them out with a screwdriver?
Old 06-25-2012, 06:58 PM
ncranchero's Avatar
OEM FORD numbers are E9UZ-9B307-A & E9UZ-9B307-B. Dorman part numbers are 5/16" (800-007) & 3/8" (800-008) fuel lines. The kit containing both sizes is 800-017. IDK about the o-ring seals. Just pry them out & snap them back into place.
Dorman lists 800-013 2 Each - 5/16" and 3/8" Fuel Line Viton O-Rings but I cannot confirm this is for these lines.
Old 06-27-2012, 02:39 AM
Howdy,
I am doing a frame swap with a 64 F100/600 body to a 94 F350 frame. I am having some slight issues with integrating systems and hope you guys in this forum can help. Here is my Build link http://www.ford-trucks.com/forums/11...storation.html
I know this a very very open ended question but what will i need to do to make my 94's fuel system (tanks and lines) work with a mechanical fuel pump on a 390. It is an area of my build that i have completely overlooked and i know almost nothing about. I am hoping that someone will have an easy answer. All advice appreciated!
Thanks.
WhitefishBoy64
Old 06-27-2012, 06:52 AM
ncranchero's Avatar
Are you going to do a single or dual tank? Single tank should only require a low pressure lift pump (if any at all) like the 91 & older models that used the frame rail mounted high pressure pump. I mean, your old 64 didn't use a tank pump at all. The 390 doesn't know what kind of tank it's sucking fuel from. Pull the pump/sender, remove the pump module, extend the pick-up tube to the proper length, block off the existing return line port and see if it doesn't satisfy the supply needs. Put an old-school filter screen on the new pickup tube!
Old 06-27-2012, 12:08 PM
Quote:
Howdy,
So the 91 and older tanks and pumps are different? I would like to have the largest fuel capacity as possible so keeping the dual tanks would be preferred. My 64 had 3 tanks with a manual valve selector under the seat. I would be just fine with having to manually select which tank i am sucking from and which tank the gauge is showing. I parted out an 85 F250 last summer that had dual tanks and i still have them along with all the fuel lines and anything that i thought would have been of use this summer with my current build. My 64 also had an inline fuel pump that was mounted on the frame under the rear of the cab. I have not done any research on that pump yet to see what it is. If the 85's tanks have the "lifting" pumps, could it be as simple as replacing my current ones with those? what would need to be done with the return lines then if i wanted to keep dual tanks? what would need to happen with wiring so far as power to the lifting pumps if i am only "pulling" from one at a time?
Thanks
WhitefishBoy64
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
04, 73, 99, connect, connectors, f150, find, ford, fuel, high, inline, line, pressure, pump, quick, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
