Plate in front of rear shock??
https://www.ford-trucks.com/forums/1...nion-seal.html
Well, it started as a rear pinion seal R&R, morphed into a slip yoke lube job and finally (as Neil so aptly stated, 'that anti sway bar isn't needed for that pinion seal fix') the hellwig install slipped in there under wife's radar.
Somehow the mechanics at the auto repair shops are able to up sale all those other non essential services and the wife just says ok and we husbands have to resort to these covert operations.
I got the diesel and mine do not have the plate on the pass. side. The bracket is exactly the same as the driver side. My installation is exactly like "bfediuk" his istallation below. He took a lot of pictures for is V/B code springs and Hellwig rear sway bar installation.
https://www.ford-trucks.com/forums/1...-hauler-3.html
It protects the shock body from rocks. I'm guessing somewhere in the history of testing this vehicle that it suffered a "rock throw" that punctured the shock. The shield gets added then later gets deleted for a cost savings...just a guess though. The other shock doesn't need it because it's behind the axle (mostly).
#28
#29
#30
In a past life I ran full vehicle durability for the South American Dakota, we ran here in the US and in Brazil and had damaged shocks in the same location as we're talking about.
