performance chips for 2010 f-150 4.6L - Ford Truck Enthusiasts Forums
Old 06-23-2012, 05:32 PM
wdbutchreed wdbutchreed is offline
wdbutchreed is starting off with a positive reputation.
I see advertisements for performance chips for my Ford F-150 4.6 L engine. Their ads usually say increase your mileage 4-7MPG, 35-70HP increase and torque increases. Do these really work or are they a rip-off as I suspect. The one that popped up when I visited my local Ford dealer site was for GForce Performance Chips $69. Also they claim they will not void your warranty, how can that be when you have to tap into the wiring controlling the IAT sensor. I bought one of these but I am thinking of sending it back unless I get some positive feed back.
Old 06-23-2012, 09:19 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
you want more power?
go buy a SCT X3 and get custom tunes for the truck written. Be about $400 all told for the programmer and tuning.
I suggest 5 Star Tuning or Troyer
Quote:
send that POS back now. you are...no, YOU WILL BREAK YOUR MOTOR if you use that thing
that thing is a resistor. you place it between your IAT/MAF and the PCM. it modifies the signal sent to the PCM. basically it tells the PCM that the motor is 30-40F hotter. this causes the PCM to send less gas...aka it leans out the motor.
the more lean the A/F mixture, he more power you make. fine and good until you reach a point where cylinder temps are too high and you melt a piston. a 12:1 is "safe". the 09+ trucks see 15:1 at highways speeds...but that is with Ford's programming
Old 06-24-2012, 06:24 AM
66fdtrucknut 66fdtrucknut is offline
66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.
The best upgrage performance wise I did with my 4.6 was to trade it in on a 5.0.
Old 06-24-2012, 01:45 PM
Thanks for the feedback, this thing is on its way back, I am glad I checked!
Old 06-25-2012, 04:11 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
You will never see those gains out of any chip or programmer in a gas motor. Contact Mike @ 5Star, I run his tunes in mine and the shifting alone is worth the price. You won't read anything bad here about him, I have no experience with Troyer however.
Old 06-27-2012, 01:29 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
That ad is total bogus, you were right to suspect its a rip off. A good out of the box tuner for the 4.6 is Edge CTS. Paid 585$ for mine.
Edge Products| Products
Tuner ramhunter5877 2004 - 2008 F150 2 04-28-2015 03:08 PM
Performance Chip with out a DPF delete KR250 6.4L Power Stroke Diesel 17 01-27-2014 11:56 PM
Would like to increase fuel mileage CT_2012 2009 - 2014 F150 19 07-16-2012 06:48 PM
Performance chip agator 2004 - 2008 F150 36 02-28-2012 06:45 AM
Chip for 2005 Ford F250 FX4 6.0L Power Stroke coliervile Computer Chips & Tuners 4 11-14-2011 06:47 PM
Tags
2010, 46, 4x4, 6l, chip, chips, f150, f250, ford, fpr, mpg, performance, performce, powered, ranger, tuner, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
