Rear end noise
Old 06-23-2012, 03:19 PM
jeffmeyers351's Avatar
jeffmeyers351
jeffmeyers351 is offline
Rear end noise
at work we have a 1993 ford f150 2wd, the truck runs and drives good but the tred on the back tires are wearing on the inside instead of wearing evenly and going at slow speeds the rear end kind of makes a grindind noise and squeels like metal against metal, the rearend is full of fluid, the truck also has a 302 with automatic tranny and has 315653 miles on it, original motor and tranny, does the rearend have a bad bearing or could something else be causing this
Old 06-23-2012, 04:34 PM
CletusSnow's Avatar
CletusSnow
CletusSnow is offline
Sounds like you're gonna need some kind of part replacement. As long as you dont live where it gets super cold, if it were mine, i'd drain the fluid and replace it 100% with lucas engine oil additive, I've used it many a time on squealers with no issue.
Old 06-23-2012, 04:35 PM
sccamper's Avatar
sccamper
sccamper is offline
Sounds like bearing or bent axle. Need to jack it up and check for loose motion.
macster60
06-20-2014 07:16 PM
jrod117
1997 - 2003 F150
12-10-2010 07:26 PM
Kikir
04-18-2008 12:58 PM
fazerman
1999 to 2016 Super Duty
08-25-2006 10:18 PM
RedneckF-150
1978 - 1996 Big Bronco
21
10-08-2003 12:48 PM
Quick Reply: Rear end noise
