You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
This is "effective July 1, 2012, all model year 1997 or newer non-exempt diesel-powered motor vehicles that have a GVWR (gross vehicle weight rating) under 8501 pounds (hereafter referred to as "LDDV") are subject to an OBD II emissions inspection, in addition to the safety inspection. (A LDDV less than two model years old, registered as "historical", or 26 or more model years old is exempt from the emissions test.)"
This is from NYVIP Message 82 dated 6/20/2012
This seems a little strange now as the DMV has limited the number of inspection stations per county because, they "don't have the resources" to check on the current stations.
__________________ [/SIGPIC]George 54 F100, 78 F150, 79 F150, 86 F250, 87 F250 Member #5 Boy you ain't Right Club Official Slackmaster #15
Interesting - here on Long Island, there is still a plethora of inspection stations at local mechanics.
They have actually stopped sniffer-checking my 2001 V10 - so no emissions inspection whatsoever for my truck. I figured they couldn't justify the cost to the mechanics of having a separate sniffer setup that must cost big $'s.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. ®
Morning Art.... are they still doing an emmissions check on your truck by using the ODBII port??
__________________ Neil aka Tiny aka Hugo...... Official #2 Slackmaster & Pyroslacker Extraordinaire
2001 F150 XLT Supercab 4x4 & 2008 Edge SEL AWD To Join The NEW YORK CHAPTER CLICK HERE RIP Phil, phil6608.... you will be sadly missed my friend
Nope, they never did. My truck is OBD-I - not -II - no catalytic converter monitors, nor O2 monitors.
Because it's a passenger vehicle with registered weight of around 5600 lbs, the answer was to manually change the weight code to >8500lbs GVWR and the machine would call for an idle-sniffer check. If they didn't manually change the weight code, it would call for an OBD-II check and fail.
If it was commercial, and the reg had the GVWR on it, it would automatically pick that up and call for an idle sniffer check.
Now, they don't even bother with the idle-sniffer, and it's just a safety check.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
