'04 F-150 No Reverse!!! - Ford Truck Enthusiasts Forums
Old 06-22-2012, 04:43 PM
AbNorth AbNorth is offline
AbNorth is starting off with a positive reputation.
Question '04 F-150 No Reverse!!!
I went to reverse and on my dispaly it said transmission failure, then i checked the codes that came up and they were
  • P0171-Air fuel mixture lean
  • P0720-Low output speed sensor
  • P2160-High output sensor
  • P0000-???
I have no idea what is happening. The shifter will engage to all gears except i have no power on reverse now only idle. I have full power on Drive. What is wrong???
2008 F150 Lost reverse Thad N Beach 2004 - 2008 F150 3 01-13-2017 10:54 AM
HELP! Truck Stalled, Won't Start, & Have OBD Codes flare-f150 1997 - 2003 F150 1 07-20-2015 06:42 PM
04 F150 with Reverse gear problem geoshanna 2004 - 2008 F150 2 11-11-2013 08:20 PM
05 expedition output speed sensor slider6075 Clutch, Transmission, Differential, Axle & Transfer Case 14 10-23-2012 09:27 PM
Transmission Malfunction sick150 2004 - 2008 F150 4 02-02-2011 10:46 PM
Tags
04, 2004, 2006, 42l, 54, 87, cold, f150, ford, power, reverse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
