Airbag Code #32 - Ford Truck Enthusiasts Forums
Airbag Code #32
Old 06-22-2012, 01:38 PM
MCR500 MCR500 is offline
MCR500 is starting off with a positive reputation.
Airbag Code #32
Gentlemen,
My sons truck( 01F150 Supercrew, 4wd, 122K), airbag light flashing code 32.
I have searched this great site, and the concensus is that the clockspring is bad. In almost every case, the posts also say that a symptom of the bad clockspring is the horn and CC functions fail to work also.
My issue is his horn and CC STILL work. I don't want to tear the steering column apart to replace the clockspring if there could be another cause of the code 32. I have noticed that his "key reminder" chime rings with the door open, whether the keys are in the ignition or not. Don't know if it related to a bad clockspring?
Can the clocksrping still throw the code, yet these functions still work? Could there be another cause for the code other than the clockspring?
Any suggestions would be appreciated in advance. Thanks, Mike
Old 06-22-2012, 02:04 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Code 32 is driver side airbag circuit high resistance.
It needs to be taken apart to find the cause and not just replace parts on luck.
Either way it has to be looked at.
Use caution working on an airbag system or it will blow and you could get hurt.
Remove power by discinnecting the battery and leave it for awhile.
Then remove the air bag and place it out of the way.
Never try to measure it's resistance or it will blow on the spot from the meter's battery circuit.
Best to get the shop procedure to follow for safety and learning what the circuit is.
Good luck.
Old 05-27-2014, 12:55 AM
TexasCoastie TexasCoastie is offline
TexasCoastie is starting off with a positive reputation.
I have a 2001 F150 with a code 32 as well...My air bag light flashes for about 30 seconds and then stays lit. What are all the components in the system that could fail and cause the 32 code?
Thanks,
Clockspring?` ChRoNo16 1987 - 1996 F150 & Larger F-Series Trucks 7 12-04-2016 01:01 AM
97 f-250 clockspring Sdowdle541 1987 - 1996 F150 & Larger F-Series Trucks 4 05-24-2016 11:31 PM
Horn and Cruise don't work. Nope not Clockspring! Weird horn issue. Wildvettes 1999 to 2016 Super Duty 4 05-11-2016 12:49 AM
clockspring 62star Aerostar 2 01-03-2013 08:11 AM
93 Aerostar can clockspring be repaired Hosea2003 Aerostar 9 08-26-2012 10:17 PM
Tags
2000, 32, 94, aerostar, air, airbag, bag, code, econoline, f150, f250, ford, ranger, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
