SCANNER NOT COMMUNICATING WITH PCM...7.3
Well,thats what was pissin me off. Pin 16 had power. The 2 ground pins showed a bad ground. What brought my attention to the idm was the idm relay started clickin rapidly. Although not at first. It was intermittent
This is the SD 7.3L forum, so we are from the generation where OBDII is common. The '94 was pre-'96 - '96 was when the OBDII was put into full effect on most vehicles. I don't know how well the pre-'96 OBDII ports work.
You can try to set the protocol manually - SAE J1850 PWM. If the MODIS unit asks, the truck is non-OBDII compliant. I'll explain that last part: There are "universal" PIDs with universal addresses - we have extended PIDs with non-universal addresses.
Could this cause a transmission mis communication?
I found this thread and hope you guys are still on here. I currently have my truck at a transmission shop and it is failing to communicate with any of thier equipment. I had some shifting issues with my 4r100 and took it in . The overdrive light has been flashing. But the truck wont communicate any codes. They are going to pull the pan and manually inspect and proceed to electrical testing if the pan shows no obvious issues. If it would just communicate the problem we would be ok. Any ideas? Thank you for your help.
Obd port doesn't work/ IDM already replaced
I got power in the cigarette lighter, all the fuses are fine, I already replace the IDM,but still have a problems with the obd port. Truck run like S#;€×...#$@
T
516 31st b-ham. Diesel worx is the name of our shop. Do u need a mechanic? Or help with somthin? dont hesitate to come by or ask man. Thats why im here. My number is 205-675-4617.
Yup,what I got here is a wiring gremlin. I think a ground might be the cause. Ill find it.
Trying to find where fhis goes cig lighter fuse not blown and obd2 not working used multiple obd2 found this plug under dash unplilugged but dont knkw where it goes
sudsmcduff
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
13
12-24-2013 11:43 PM
bluestang65
1997-2006 Expedition & Navigator
08-09-2011 10:10 PM
04, 05, 60, 73, 96, communicate, communication, diesel, excursion, f350, ford, pcm, powerstroke, scanner, wont
