Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 06-22-2012, 07:35 AM
snelldawg's Avatar
snelldawg snelldawg is offline
2012 Ford F-350
snelldawg is starting off with a positive reputation.
Adding radio control to XLT steering wheel
Just curious if anyone has done this? And if so, is it 'plug and play'?
__________________
2012 F350 XLT 6.2L CC LB FX4: Line-x, Bilstein 5100 shocks and stabilizer, OEM 20" wheels, Recon smoked cab and mirror lights
2005 F250 CC King Ranch (Gone but not forgotten)
"It's better to have too much and not need it than not have enough"
  #2 (permalink)
Old 06-22-2012, 09:16 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is online now
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
What's your wheel look like now? Does it have blanks where the buttons are or is it completely smooth (meaning you'd need a new steering wheel)?
I was just looking at the order guide and it looks like the audio controls weren't an option in the XLT, wonder if any programming (BCM) would be required, etc.
The last 3 pages of the attachment below outline the connections for the steering wheel controls, may help get an understanding how it's hooked up.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #3 (permalink)
Old 06-22-2012, 09:32 AM
snelldawg's Avatar
2012 Ford F-350
The steering wheel has a plastic peice that can be removed. That's where the control would go. It could be pre-wired behind that peice of plastic.
I found some info related to adding the crusie control (which I already have) and that required a reprogram of the BCM.
If I could have ordered this from the factory I would have, but I didn't want most of the other stuff that was included in the 'package'.
__________________
  #4 (permalink)
Old 06-22-2012, 09:43 AM
2011 Ford F-350
Gotcha, yeah I think the steering wheel controls are part of the Lariat..
Anyways, I'll keep my eyes peeled if I come across anything, otherwise I don't have much to offer!
__________________
Matt
  #5 (permalink)
Old 06-22-2012, 09:50 AM
snelldawg's Avatar
2012 Ford F-350
Thanks!
Someone has asked this question in the SD forum and there weren't any responses.
If I could buy that part for $50 and snap it in and be all set I'd do it in a second. If it involves more than that then I'm out, LOL.
__________________
  #6 (permalink)
Old 06-22-2012, 10:05 AM
2011 Ford F-350
This looks involved (link below is for an '08, probably a similar process):
http://www.ford-trucks.com/forums/97...ls-2008-a.html
__________________
Matt
  #7 (permalink)
Old 06-24-2012, 10:25 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
I didnt think you could get the truck without the steering wheel control. I got it on my XLT, but I did get the XLT premium package, maybe that's where it comes in because I know I did not order that, but it is great, use it all the time.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #8 (permalink)
Old 06-27-2012, 11:41 AM
SlickYamaha's Avatar
SlickYamaha SlickYamaha is offline
Garage is empty, add now
SlickYamaha is gaining momentum as a positive member of FTE.SlickYamaha is gaining momentum as a positive member of FTE.
I had thought about this as well. I am not sure, but I wold suspect that popping off the plate and installing the switch is ideal, but most likely not going to work. I have noticed that a ton of the wiring and such for these trucks is pre ran from the factory, and simply needs to be plugged in. (i added fog lights, upfitters, cab lights) and most were already pre wired, minus the cab lights where I had to replace the harness. I would think this would be the case for the controls as well. I think you have the harness for cruise control only, and not for audio controls, so the harness would have to be replaced with one for both. Then, you may need to get a new module for the headunit itself. I purchased an aftermarket Pioneer, and if my truck had the steering wheel controls, there was like an additional $60 module that had to be installed for them to work.
Should this work for you PLEASE update this, I would love to do it as well. For now, I may just order Pioneers strap on steering wheel control for my head unit.
Click the image to open in full size.
__________________
-Jay-
'11 6.2L F250 Super Duty -- Crew RollBak cover - Recon Smoked all around - 37" Toyo MT - 20" BMF Novakane - 6" Pure Performance Lift - Train Horns - Bulldog Lighting
  #9 (permalink)
Old 06-28-2012, 01:18 AM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
2011 Ford F-250
My Garage
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
[quote=2000silverbullet;11981789]I was just looking at the order guide and it looks like the audio controls weren't an option in the XLT...
I may have missed it but what controls are we talking about? I have volume, can change channels, change media etc. Not a premium system either. Well... it didn't used to be.
Very nice to have indeed.
__________________
2011 F250 6.2L XLT Crew Cab 4x4, 3.73.
Golden Bronze Clearcoat Metallic
2012 Coachmen Freedom Express 292BHDS
ARE Z Series Cap & BedRug
Audio upgrade
  #10 (permalink)
Old 06-28-2012, 05:21 AM
2011 Ford F-350
I meant the audio controls on the steering wheel, but apparently that's not the case since KMONTY has 'em.
__________________
Matt
  #11 (permalink)
Old 06-28-2012, 06:15 PM
fz1dave's Avatar
Super Duty
2011 Ford F-250
My Garage
Those are the ones. I've got 'em too.
__________________
Audio upgrade
  #12 (permalink)
Old 06-30-2012, 05:59 AM
snelldawg's Avatar
2012 Ford F-350
The audio control on the steering wheel was part of a package....I think that it was the Premium as mentioned above. I didn't want a few of the options in that package so I didn't order it.
Slick Yamaha, sounds like this is more involved that I want to deal with. I was hoping that this was plug and play but it sounds like it's not. Thanks for your feedback.
__________________
Tags
control, controls, f250, f350, ford, hooking, radio, steering, stereo, upgrade, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
