About to throw in the towel
#76
#77
Still do not have an answer to the 6 cyl. question as to which one used a chain on the timing gears?
I'm looking in my 49-51 repair manual and it shows an H & M series 6 cylinder engines that were used and both have the gears meshing with no chain.
By the way I do not have a 6 cyl. in my truck but am just interested.
TractormanBill
TractormanBill
#80
Ref 1952 supplement
'Happy you have persevered! You all have helped the rest of us tremendously by trouble-shooting out loud, so to say. The 1952 215 OV eng is the one I have in my F2. The 1952 shop manual supplement has the 215, 279, & 317 eng's as they were new that year. The timing marks are set to the first tooth engaging each of the gears on the drive side of the chain. That is, the gears don't touch each other, but an imaginary line drawn on the outside radius of the gears on the drive side will be where the timing marks should be placed.
By the way, I missed why 51 Panel is called, "Ilya."
#81
#82
Ilya,
I didn't keep up on this post but you brought me up to speed on it. I know from personal experience the frustration isn't worth it but it sure does feel good when you finally find the correct solution to a problem and all works as it should.
Why did Ford set the gears up different than what everyone else? Why did they have the firing order opposite than the others, starting with #1 on the passenger side and not on the driver's side? Who know, AX's explanation for the gearing sure sounds like typical Ford to me.
#83
#85
#86
#88
AFAIK, '52 was the first year for any Ford engines that used the LinkBelt style chains for the cam, so I don't know what these would be left over from.
#89
Today they make a whole line of cranes (http://www.linkbelt.com/.
#90
