About to throw in the towel - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 07-04-2012, 02:45 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
We found the problem.
Timing marks aligned together, while the manual calls for them to be seven links apart (12 pins). Timing chain was reset and compression tested again. It's up at 110 where it should be after a rebuild.
We'll close up the engine and re-install everything that was removed today on Thursday. Hoping to fire it up on Friday or this weekend.
  #62
Old 07-04-2012, 07:03 AM
tractormanbill's Avatar
tractormanbill tractormanbill is online now
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
Smile 6 cylinder timing
Ilya,
I'm so happy you found the problem with the engine after all the headaches. I have been wondering for the last week how it was coming. It is like watching a tv program that was continued.
Happpy driving!!
Now possibly you will have time to police up the parts we have been going back and forth about over the last few months.
TractormanBill
  #63
Old 07-04-2012, 08:19 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Glad you sorted it out Ilya. Looking forward to seeing it back in the truck and going. I'll be discussing this with my engine builder too. Stu
  #64
Old 07-04-2012, 10:52 AM
dennisb56's Avatar
dennisb56 dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.dennisb56 is gaining momentum as a positive member of FTE.
That's real good news, one step closer!!
  #65
Old 07-04-2012, 10:56 AM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Congratulations! Always nice to find the solution, even if it did drive you crazy for a while. I hope the engine builder compensated you for your headaches or has a least learned the lesson. Some of us just don't like to read directions sometimes...
  #66
Old 07-04-2012, 11:23 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Hmmm, kinda what I thought....glad it wasn't anything more serious! Too bad you had to go through all of the wondering and worrying.
That motor should last forever....get it together and drive it!
  #67
Old 07-04-2012, 11:40 AM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Not to this interesting thread, but anyone know or speculate why Ford broke from normal industry standard protocol when they went into the OHV engines? They went back std with small blocks and the FE series.
  #68
Old 07-04-2012, 11:48 AM
Lance Hogan's Avatar
Lance Hogan Lance Hogan is offline
Lance Hogan is starting off with a positive reputation.
Thanks for reporting your findings.
  #69
Old 07-04-2012, 11:51 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
Timing marks aligned together, while the manual calls for them to be seven teeth apart. Timing chain was reset and compression tested again. It's up at 110 where it should be after a rebuild.
We'll close up the engine and re-install everything that was removed on Thursday. Hoping to fire it up on Friday or this weekend.
Not exactly on subject, but I look at this picture, I do some work around cranes here and there, and I see "LINKBELT FMC" on that cam gear.
I feel a cross between work and play...I think I need to find a councelor...I don't like it.
On a positive note glad you figured it out!
Another classic case of...if you want to done right, do it yourself.
That's just my excuse for not being able to pay anyone to do anything for me..
Hang in there by the towel tag Ilya! You are almost there buddy!
  #70
Old 07-04-2012, 12:35 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Ilya,
Let me show my ignorance (happens a lot on here).
I look at that picture of the timing gear & I don't see a thing about timing
marks lining up. What are you looking at on that pic that jumps out at you? Just watching & learning....
Glad you found the problem!
Ben in Austin
  #71
Old 07-04-2012, 01:07 PM
tractorman
6 cylinder
Ben, get your glasses and you can see a small circle on the top gear that the builder ligned up with the circle on the lower gear which lots of engines use this method.
I'm looking in my 49-51 repair manual and it shows an H & M series 6 cylinder engines that were used,
Both of them have the crank and cam bear meshed with no chain. Of course the marks on them line up like the engine builder tired to assemble yours with the marks together.
What 6 cyl. used the chain?
TractormanBill
  #72
Old 07-04-2012, 01:15 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Ben,
A camshaft has to be in coordinated time with the crankshaft rotation so the valves open and close at the proper time compared to their piston position. The cam usually is designed to turn at 1/2 the crankshaft speed. To drive the camshaft and keep it in proper time a timing chain or toothed belt or gears are used.
To orient the cam drive at the proper relationship some sort of marker is used. If you look closely at the picture above you will see a "o" stamped on the crank gear and the cam gear (harder to see on the cam gear, look on the tooth below the "e" in link belt)
On most engines the two marks are aligned with each other when the cam gear is bolted in place to set the timing. I suspect Ford in his famous frugality (read CHEAP!) decided to use a gear already in inventory from and marked for another engine on this motor. To properly time this engine the timing marks must be offset by 7 teeth. If you don't carefully read the manual, most mechanics would set the marks in alignment, as done on almost all other engines.
Two lessons to be learned: 1. Always read the directions, no matter how many times you've done something before. 2. Ford often bucked the system to use parts already in inventory to save money.
  #73
Old 07-04-2012, 01:23 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
YEA !!!!! Truely a Happy 4th for Ilya .Good for you . Perserverance pays off .
  #74
Old 07-04-2012, 01:28 PM
ben73058's Avatar
Thanks Guys - I now see the faint circles that line up. I've seen timing marks before - but they were lines & I was looking while shining a timing light on them. I continue my truck education daily on here!
Ben in Austin
  #75
Old 07-04-2012, 01:34 PM
tractorman
6 cylinder
Still do not have an answer to the 6 cyl. question as to which one used a chain on the timing gears?
I'm looking in my 49-51 repair manual and it shows an H & M series 6 cylinder engines that were used and both have the gears meshing with no chain.
By the way I do not have a 6 cyl. in my truck but am just interested.
TractormanBill
ANOTHER 7.3 NO START, HPOP RELATED..NEED YOUR IDEAS nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 72 04-04-2016 10:22 AM
Help, no spark and no injector pulse billy main 1997 - 2003 F150 2 01-31-2016 01:48 AM
Fairly simple question about the 300 six and a story of machine shop woe Nathan Plemons Ford Inline Six, 200, 250, 4.9L / 300 20 11-20-2015 05:29 PM
IDI Oil Cooler Thread Chevy_Eater Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-17-2015 10:17 PM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 08:55 PM
Tags
1956, 2003, cache, explorer, f100, ford, housing, leak, parts, thermostat, utah, valley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
