About to throw in the towel - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-22-2012, 03:52 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
Originally Posted by raytasch View Post
And I would ask, what portion or area of the engine hit the floor when it was dumped?
Left front lower engine mount bracket, upper left corner of the head, left lower rear mount for the transmission. The valve cover was not on the engine.
  #32
Old 06-22-2012, 05:06 PM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
I had an engine once where the rubber on the harmonic balancer seperated from the steel underneath. It looked fine to the eye but had rotated enough to put the timing marks almost 40 degrees out causing a massive compression loss. Does the engine have a harmonic balancer? If it is NOS it could be the issue.
  #33
Old 06-22-2012, 07:17 PM
firstrider's Avatar
firstrider firstrider is online now
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
Ilya , no giving up . Failure is not an option . The truck will not beat you .Any one could throw in the towel . If you get a spare moment take a pic of the best bumper and send . I have truck $$ burning a hole in the pocket . Thanks , Denny
  #34
Old 06-22-2012, 07:57 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Ilya, did the rebuilder give any warrenty? It just seems to me that he should have you tow it over to his shop and deal with it, or at least work with you to solve the problem. Its hard to watch as someone we all care about go thru this frustration. Just know it will run, and run nice, dont give up.
  #35
Old 06-22-2012, 09:09 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Ilya, you may want to pull the timing cover and check the timing marks. These sixes (and Y blocks) have the marks offset from each other by 12 pins in the timing chain. If your builder assembled it "straight up" , (dot to dot) it will never fire. Easy mistake to make...
An old Motors repair manual has the diagram for correct alignment...
  #36
Old 06-22-2012, 09:20 PM
51PanelMan's Avatar
Ok. Here's an update.
Just spent some time going over a few things. We performed a leak down test that resulted in the cylinders holding pressure. We then simulated a valve leak by cracking the valve open slightly. After the valve was released, the cylinders still held pressure.
Performed what "tractormanbill" suggested. With the valve cover off, set the #1 cylinder at TDC per the timing mark on the dampener. Valves were closed and had lash. The distributor rotor was pointing at #1, which confirmed the cam timing was correct. We then manually rotated the crankshaft 360 degrees back to TDC. Exhaust valve was open, so cam timing appears to be accurate. Rechecked the compression and it dropped down to 10-15psi versus the ~30psi we had a few days ago after oil was squirted into the cylinders.
Checking with a thumb placed against the spark plug hole, for compression stroke, there was heavy amount of suction on the intake stroke and minimal pressure on the compression stroke. So the motor has a lot more vacuum than air discharge.
Since we have fuel, spark and air, I don't understand why it wouldn't have compression. What if the timing chain is off by a tooth or two, would this create a no compression issue? If the cam was installed incorrectly first and then the valves were set to the incorrect cam timing, would this create no compression?
I'm ready to take a dynamite stick to rectify the situation!
  #37
Old 06-22-2012, 09:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Checking #1 is fine but you need to verify some others as far as cam timing.
You shouldn't have suction on the intake stroke; that means the intake valve isn't opening or the throttle was closed tight.
  #38
Old 06-22-2012, 09:32 PM
51PanelMan's Avatar
Thanks for the idea, Scott. We checked the shop manual earlier and confirmed that the marks are offset like you mentioned. That also crossed our minds. Now that you mention it, that could be the culprit.
I gave the rebuilder the shop manual to aid him in assembly. I only hope that he referenced the shop manual.
I called the rebuilder after we were done, but there was no answer. He does work tomorrow and my friend, who's a much more knowledgeable mechanic than me, will call him tomorrow. I will then follow up with a phone call or an actual visit.
  #39
Old 06-22-2012, 09:47 PM
timboy's Avatar
timboy timboy is offline
timboy is starting off with a positive reputation.
You say lots of vacuum and not much compression. Earlier you said something about the rings being upside down. Sounds even more like it to me and I don't know anything about rebuilding an engine. Is that still possible ? Tim
  #40
Old 06-23-2012, 03:39 PM
ALBUQ F-1's Avatar
postin' fool
I think the only thing that could kill compression that uniformly on all cylinders is cam timing. Upside down rings usually just makes massive amounts of smoke.
Ilya, did the builder set the valve clearances? If he set them with the cam out of time, the clearances will appear to be "right", but at the wrong time. For example, the lifter could be halfway up in its travel but you could set the lash to be .018" or whatever at that lift. You'd end up with almost no valve travel.
I don't think the 215 is an "interference" engine, but it's possible the valves kissed the pistons and bent the valves. That will kill compression quickly. A leakdown test would show that right away.
  #41
Old 06-23-2012, 05:47 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Doesn't matter what the year of the engine is Ilya, they all could do this. Just depends on what was done and how it's assembled. IMO, the older the engine, the more simple it is, though.
It sure sounds to me like the cam is out of timing. Even if the re-ground cam didn't have the longer pushrods that it may require, it'd still run and build compression. The valvetrain would just be noisy while it was running. They would have had to really grind the **** out of the cam in order for a stock pushrod not to allow enough air in. With your finger gettin sucked in really hard when turning over tells me the intake valve is not opening when it should.
  #42
Old 06-23-2012, 06:32 PM
jred jred is offline
jred is starting off with a positive reputation.
engine
ok your engine sounds like the cam is out of time with crank a quick way to check this is with what we call the split overlap to do this take the spark plus out so you can turn the rngine over easley turn the engine in the normal rotation watch the exhaust valve open and then start to close as the exhaust valve is closing and the intake valve starts to open make both valves the same meaning the exhaust and intake are the same height in relationship to each outher then look in the #1 cylinder and the piston should be a top dead center DO NOT GO BY YOUR DAMPER as it could have sliped and not read true tdc this is called the split over lap and its allways at tdc even with a performance cam when the cam grinder ground your cam or reground your cam they don't take very much off of what we call the base circle even when regrinding the lifters they only take as little as possable as they will grind through the hardness of the lifter face and the cam and lifters will wear very fast most of the time when you have problems with your engine i would suddress that you pull your own engine back out because you will be more careful with the r/r then some guy doing it for free not that they want to have problems but sometimes something bumps into your new paint job or something comes up missing off your truck hope this helps john
  #43
Old 06-23-2012, 07:07 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Quote:
Please allow me to help reduce your "misery quotient" by coming right over there,soon as I've finished my sandwich,and haul away your problem.Won't charge you too much,either.
  #44
Old 06-24-2012, 12:27 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Quote:
What an admirable offer. You are a model for the rest of us. You completely unselfishness is amazing. I can only hope to be as good a person as you some day.
There is hope for humanity
  #45
Old 06-24-2012, 12:35 AM
ibuzzard's Avatar
Thank you,Bobby.I can only do what One Man can do.......
ANOTHER 7.3 NO START, HPOP RELATED..NEED YOUR IDEAS nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 72 04-04-2016 10:22 AM
Help, no spark and no injector pulse billy main 1997 - 2003 F150 2 01-31-2016 01:48 AM
Fairly simple question about the 300 six and a story of machine shop woe Nathan Plemons Ford Inline Six, 200, 250, 4.9L / 300 20 11-20-2015 05:29 PM
IDI Oil Cooler Thread Chevy_Eater Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-17-2015 10:17 PM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 08:55 PM
Tags
1956, 2003, cache, explorer, f100, ford, housing, leak, parts, thermostat, utah, valley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
