Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 06-22-2012, 12:15 AM
expydaddy expydaddy is offline
Garage is empty, add now
expydaddy is starting off with a positive reputation.
Dorr Sticker Tire Pressure?
Hello. I have a 99 xlt, 5.4, 4x4. I have owned her for about three years now and she is excellent. After more closely examining the door tag, I swear it said ft tires 30 psi cold. Rear tires 35 psi cold. I have always run on a constant 35 all around. Is there a 5 lb. difference between front and back? If so, would that cause front end suspension damage? Thanks for your help.
  #2 (permalink)
Old 06-22-2012, 05:48 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
Yes, that is correct. My wife's Explorer also has the same pressures listed on the door sticker. I do not believe it will cause any suspension damage.
__________________
Craig
98 XLT 4X4 5.4 W/aftercooled Vortech S/C, custom tuned w/lightning maf and 42# injectors, Flexlite electric fan, Lightning Head and Marker lights and LED tails, Bilsteins, S/S headers and Magnaflow catback, Pioneer nav system and Airlift rear bags w/compressor
  #3 (permalink)
Old 06-22-2012, 11:08 AM
alloro alloro is offline
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
The major consequences to not running the correct PSI are irregular tire wear, reduced braking, and MPG changes.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #4 (permalink)
Old 06-24-2012, 12:42 AM
Boat Tug's Avatar
Boat Tug Boat Tug is offline
Boat Tug is gaining momentum as a positive member of FTE.
Quote:
I have a question about tire pressure and newer tires.
The door psi rating obviously referred to the original tires supplied with the vehicle.
The tires in 2000 were rated at a lower maximum tire pressure than the ones I am currently using. These newer tires have a 44psi rating, they are in all other respects the correct size and rating as the OEM tires.
I have been running them at 40psi all around for 20k miles and all seems just fine. My mileage, braking and tire wear seem as good or better than any previous tires. The alignment is true, tires are rotated every 5k and handling is nominal for these rigs.
Any thoughts? Different tire technology make any difference here?
__________________
Sold..... It was fun for 10 years.
2000 XP EB, A4WD, 5.4, Air LLS, Tow Pack, 168k Miles.
Tags
ford, general, lightning, powered, pressure, rated, tire, tires, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
