Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-21-2012, 11:59 PM
360andy 360andy is offline
Garage is empty, add now
360andy is starting off with a positive reputation.
95 gas f-350 fuel issues
95 f-350 Crew cab with the 460 gas 2wd dually 140,000 mileage.
Purchased this a little while back and fixed all sorts of little things but engine and tranny seem to work well. It had bad tires and before I got them replaced I filled them up and had severe vibration at around 45 mph. and then it smoothed out after that. Replace tires and front brakes and had no problems with ride.
Drove it for a week or so and the when the front tank was selected it seemed like it was getting starved for gas and when I switched it to back tank it ran smoother but not as smooth as before.
I switched out the fuel filter and that seemed to make it better for just a little bit, but then it started acting up again as I expected it to. I borrowed a fuel pressure gauge and tested fuel pressure while running the truck. Both tanks seemed to run at 30 psi at idle and then go up to 35 or 36 when driving. When on front tank running at 36 it seems to just drop to 30 or 31 and acts like no gas. Some times it drops below 30 and problem occurs.
Fuel pressure spec's
KOER 30 - 40
KOEO 35 - 45
Question is: are both front and back FDM going bad or are there some other things to look at? Could something have come loose when the truck was bouncing down the road. The radio did stop and it was a loose connection at the back of the radio.
Thanks Andy
  #2 (permalink)
Old 06-22-2012, 12:08 AM
Rinkled Ranger's Avatar
Rinkled Ranger Rinkled Ranger is offline
1996 Ford F-350
Rinkled Ranger is starting off with a positive reputation.
Subscribing! I am having the exact same issue with my '96.
Tags
96, f350, ford, gas, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
