Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 06-21-2012, 11:35 PM
davidh11 davidh11 is offline
Garage is empty, add now
davidh11 is starting off with a positive reputation.
Transmission gasket leak
I have an 01 F250 crew cab 4x4 and my tranny gasket is leaking. It is the original gasket and the second tranny. I would like to go back with the oem gasket. Does anyone have the part #? Or is there another gasket better than the oem? I want to stay with a rubber gasket with metal built in it. Thanks.
  #2 (permalink)
Old 06-22-2012, 11:28 AM
Orezona's Avatar
Orezona Orezona is offline
Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.
You def. need to stay with the OE gasket. I tried an aftermarket ONCE and it never stopped seeping.
2001 FORD F-250 SUPER DUTY Parts - WWW.HORIZONPARTSGUY.COM
__________________
  #3 (permalink)
Old 06-22-2012, 11:57 AM
duck fan's Avatar
duck fan duck fan is online now
RIP Robin
2000 Ford Excursion
duck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud of
Also, make sure your pan isn't bent somewhere along the surface where the gasket sits. It should be nice and flat all the way around.
__________________
Peter - NHRDA# 5078 - Member of the 200K+ club
2000 Excursion 7.3 - Casserly Stage 1 SS, 6637 w/ Pete's cover, van turbo, ceramic coated exhaust manifolds, IH up-pipes, and exhaust housing, RDP Billet Compressor Wheel, Live Tuned by DP tuner, Warn hubs, gauges, 6.0 IC, MBRP 4" turbo back, Frx, RDP AIH delete, RDP OCR, RDP IC boots, RDP CCV kit, John Wood Trans, Melling LPOP, T500 , Red Head Steering Box, RDP Billet Plenums, 5" lift, B-code springs. and RAS.
  #4 (permalink)
Old 06-22-2012, 05:02 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Listen to Peter.
Also, the pan can get dimpled at the mounting holes from over tightening the mounting bolts and atf will seep out. No more than 10 lb/ft of torque on those mounting bolts. Better yet, if you have a lb/inch torque wrench 120 lb/inches is good.
  #5 (permalink)
Old 06-23-2012, 07:18 AM
robbragiel's Avatar
robbragiel robbragiel is offline
robbragiel is a splendid one to beholdrobbragiel is a splendid one to beholdrobbragiel is a splendid one to beholdrobbragiel is a splendid one to beholdrobbragiel is a splendid one to beholdrobbragiel is a splendid one to beholdrobbragiel is a splendid one to behold
You can also use Mr Gasket in a can. Its like black RTV but formulated to resist oil, ATF, coolant. Stuff works great. I just did my C6 tranny on my 73 F350 and the pan was not straight. I put that stuff on and it sealed every dimple, bend, imperfection on the pan and dosent leak. And you can return to service as soon as you get done filling the tranny up. I bought it at advance auto. $15 for a 7 oz can.
__________________
PAA#128 / Rob-(02 F350 Crewcab 4x4 Longbed 7.3L) Banks Power Pack System w/tri-pilar gauges, Banks Power Elbow, Banks Turbo Back Exhaust, Banks Intercooler, Banks 1.0 housing, Banks WW Zoo-dad, HPx, FRx, CCV, AFE 6637, Hutch & Harpoon w/Dieselsite Fuel Filter, Trans, Oil, Coolant Bypass Filter, Billet Stat Housing, OCR, 6.0 Cooler,DP-Tuned Wifes-(02 Excursion Limited 4x4 7.3L) Banks Power Elbow, Banks Turbo Back Exhaust, Banks 6 Gun Programmer, Zoo-dad, HPx, FRx, CCV, AFE 6637, Hutch & Harpoon w/dieselsite Fuel Filter, Trans, Oil, Coolant Bypass Filter, Billet Stat Housing, 6.0 Cooler
  #6 (permalink)
Old 06-25-2012, 08:34 PM
Thanks for the help guys. Its always good to get some help from a fellow Marine! and others too.
Tags
73, excursion, ford, gasket, leak, leaking, pan, pickup, power, rubber, sit, stroke, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
