fuel mileage on new F250? - Ford Truck Enthusiasts Forums
Old 06-21-2012, 06:59 PM
SixPointSeven's Avatar
SixPointSeven SixPointSeven is offline
SixPointSeven is gaining momentum as a positive member of FTE.
I just purchase a F250 with the 6.7 Diesel. The MPG on the LCD screen is showing 10.5 MPG and I have about 160 miles on now. It's mostly around town driving. Can I expect to get better MPG as I drive more? WHat should I expect for MPG? I do have a 6" Pro Comp lift and 37" tires. Thanks for your help!
Old 06-21-2012, 07:31 PM
SuperDuty_Dude SuperDuty_Dude is offline
SuperDuty_Dude is starting off with a positive reputation.
You Should Get Better If you Drive More Highway Than City I Have A 2012 F250 With A 8.5 Skyjacker Lift and 37'' As Well I Get 11.5 MPG With A Diesel Supplement.
Old 06-21-2012, 07:39 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I have an unlifted 2012 F250, with 3.31 rear gear, and get around 16.5-17 around town, and >19 on the highway if I stay under 75. Got 20.5 on the way towards Dallas last Sunday (100 miles) and 18.4 on the way back (100 miles, had a regen)
Sam
Old 06-21-2012, 07:41 PM
Quote:
Originally Posted by sdetweil View Post
I have an unlifted 2012 F250, with 3.31 rear gear, and get around 16.5-17 around town, and >19 on the highway if I stay under 75. Got 20.5 on the way towards Dallas last Sunday (100 miles) and 18.4 on the way back (100, miles, had a regen)
Sam
Man i remember when i would get that good gas mileage before i lifted my Truck
Old 06-21-2012, 07:47 PM
So, all I can expect with my setup is around 11 around town?
Old 06-21-2012, 07:55 PM
Yea Thats What You Can Expect try a diesel supplement
Old 06-21-2012, 08:00 PM
Quote:
Whats that?
Old 06-21-2012, 08:01 PM
sdetweil's Avatar
Quote:
the sweet spot seems to be around 1500 rpm. I don't know what the translates to on a big tire truck. The wind effect of the lift won't help either. What gear ratio do you have? 3.55?
did they reprogram the truck for the different tire size? If not, then all the numbers are goofy.
Sometimes because of the bigger tire, you have to regear to a higher numbered ratio to get the right overall ratio back.
the tire size calculator I use says that if the speedo reads 65, with a 37 in tire vs a 31in tire, you are really going about 77 mph.... so traveling further than the computer thinks.. (ie, more MILES per gallon) were your measurements from the dash, or hand calculated?
Sam
Old 06-21-2012, 08:02 PM
Whats that?
its a fuel Additive to give you better mpg try diesel kleen
Old 06-21-2012, 08:57 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Hmm (3.55 for me) I get around 15/17 mpg just town driving, get 20ish on the highway. Your are pushing heavier tires now...
Old 06-21-2012, 09:00 PM
sdetweil's Avatar
Most folks aren't seeing any mileage improvement. I never have.
Sam
Old 06-21-2012, 09:02 PM
Sam
I get very little improvement
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Sam
Same here.
I'm not using an additive because of a MPG improvement.
If there is one, I stopped caring a long time ago because I can't notice it.
Old 06-21-2012, 09:45 PM
Dj1208 Dj1208 is offline
Dj1208 is starting off with a positive reputation.
I just purchase a F250 with the 6.7 Diesel. The MPG on the LCD screen is showing 10.5 MPG and I have about 250 miles on now. It's mostly arounf town driving. Can I expect to get better MPG as I drive more? WHat should I expect for MPG? I do have a 6" Pro COmp lift and 37" tires. Thanks for your help!
I have a 2011 4X2 with a 3:31 rear end CC 6.7 Diesel SB with 22,000 miles. No lifts or big tires and can get 27.5 mpg at 55 if I need to, but I drive at 65-70 and get 22-24 mpg depending on conditions, like wind and hills highway driving... You guys have really nice Cool looking Trucks with the 4X4, 37" tires and lifts, but paying through the nose for it at the fuel stops..
I get 17-18 mpg Towing my 8500# RV Trailer again depending on conditions... The difference between hand Cal mpg and our Dash Meter is called Idling Time.. I just got back from a vacation trip to Alaska and never got less than 15 MPG across the Rookies through the USA & Canada and back home a 10,000 mile trip.. This truck is a dream to drive and Towing.. The best thing was, no problems with truck at all.....
Old 06-21-2012, 10:35 PM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Sam
I use diesel kleen and see no difference in mileage. I have 35's and a baby lift, but I still get 14-15 in town and I don't have a light foot. Problem is I only get about 16 on the highway when I'm trying my hardest to get good mileage. My truck is just a thirsty pig and I'm an enabler.
2003 F250 4X4 PSD - How do I reset the "Average MPG" caluclator? Cecil_Stringer 6.0L Power Stroke Diesel 8 11-11-2015 09:54 AM
What MPG's should I see with a dually? white Buffalo 6.0L Power Stroke Diesel 4 09-05-2015 08:59 AM
1996 f250 4x4 460 fuel milage lawmanpinto Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 02-16-2012 06:42 PM
Is 14 mpg good? Tom Kreider 1999 to 2016 Super Duty 32 05-07-2011 03:02 PM
V-10 Mileage compared to Others... davzog Modular V10 (6.8l) 17 03-14-2006 12:03 PM
Tags
2012, 37, 62, 6lift, diesel, economy, f250, ford, fuel, gas, lifted, mileage, ride, tires, town, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
