Roof Replacement?
#31
#32
#34
redroad - The seat came with the truck. Only 2 rear bolt holes matched up right until I welded a bracket and modified the other side so it has 4 botls holding it down. It is a bench, but folds 50/50 on the back. From what i have found out is that it is a supercab seat, but i may be completely wrong on that.
4xFordFreak - A paintbooth?!? Man I'm jealous. Now you have to give it a try yourself! I did mine in a dusty warehouse/shop, I went through ALOT of tack clothes.
#35
A bit more progress....
First a picture of the issue with the bronco graveyard door hinge bushings. Kind of hard to see but like i said before the part of the bushing protruding out of the hold snapped off when the pins were pushed in. The bottom bushing in this picture is the only that didn't snap off. The doors are still opening fine and the hinges are tight, we'll see how long it lasts.
Rebuilt the rear slider with some new u channel rubber and got it roped in Also snapped a picture of the windshield that i installed a week or so ago.
I also went ahead and put in my new to me OEM dash pad. Bought it from a guy that had pulled it out of a uhaul truck.
#36
#37
Whats lurking under your hood?
These hoods like to rust through on the front edge. This one while on its way there was still solid. I figured i would fix it while i had the chance, also I was sick of seeing rust flakes every time i shut the hood.
Little bit of time with the spot weld bit and heat gun to release the glue/dampening compound that bonds the inner support to the outer skin.
I believe condensation forms and runs down to the front of the hood as well as moisture sitting on top of the grill causing these hoods to rust at the front/bottom edge. Here are the worst spots.
I'll sand blast the rusted areas and strip the rest with a DA, epoxy prime, and then weld back together and proceed with the normal paint procedure.
#38
The hood is progressing slowly, but hopefully I'll pick up the pace so I can start on my next project for the truck. I did a compression test on the 351m in the truck and came up with
1 -130 psi
2 -130
3 -130
4 -130
5 -30
6 -140
7 -135
8 -110
The 30 psi in cyl 5 wasn't really a surprise as i knew the truck had a weak cylinder and lots of blow by. I had planned to go with a 460 for the sake of simplicity and not buying another transmission until i did some more research and realized my new engine choice could bolt up to my existing NP435. With out further a due here it is.
I'll start a new thread once I get further into it. Let the hating commence!
1 -130 psi
2 -130
3 -130
4 -130
5 -30
6 -140
7 -135
8 -110
#39
1 -130 psi
2 -130
3 -130
4 -130
5 -30
6 -140
7 -135
8 -110
1 -130 psi
2 -130
3 -130
4 -130
5 -30
6 -140
7 -135
8 -110
#40
#43
Thanks! I did rope the front windshield in as well. For me the front was easier than the back, but both required the help of a buddy, lots of patience, a generous amount of soap and water and some butter knifes. i actually bought a used windshield figuring if i broke it during the install i wouldn't be out as much money.
#44
