Excursion paint code - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-21-2012, 01:45 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
My ex has the dreaded paint peel under the window trim and I was looking for the color code. It reads B4. Did ford change the color code? It's a 2000 ex limited with the very dark read any help would be great thanks!
Old 06-22-2012, 09:35 AM
locknload223's Avatar
locknload223 locknload223 is offline
locknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud of
It is B4, Chestnut Metallic Clearcoat, but I remember there was something weird about the B4 code when I first bought my truck, it didn't jive most places.
Old 06-22-2012, 09:54 AM
Kdr358's Avatar
I was able to get the paint after I googled it lol I Just never found it listed in any of the tech folders
Old 06-22-2012, 09:59 AM
Yep, I was super frustrated until I asked here a few years ago. Do you have any pics of the peeling? I'm curious now. My roof has tiny paint cracks but no peel.
Old 06-22-2012, 10:01 AM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
Quote:
Good point. We will have to add it. We do have a temp Tech Folder that is in the works: http://www.ford-trucks.com/forums/11...l#post11898840
Old 06-22-2012, 11:55 AM
Kdr358's Avatar
Nice! I'm sure there's others with thr color code problem. Was this color a special order from the factory? I've only seen 2000 limited models with the color combos like that. I'll snap some pics when I get home, I also have the roof rust problem
Old 06-23-2012, 12:03 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
I just went threw a big paint ordeal with my X trying to get both main paint and trim paints.....
Here is the deal. At the time of the vehicle rolling down the assembly line the paint containers (vats) are filled with whatever paint maker is giving the deal that day/week. So the paint code on the sticker can be from PPG, dupont, or whatever other paint supplier ford uses. What I found out with my X is the paint they used was from PPG hence the problems I was having getting a matching paint from dupont. In the end after a few different "batches" I had a paint that was very close to original but still a shade off.
The best thing to do is take the gas door off and take it in or take the whole X to the paint store of your choice. They should be able to either shoot it with a paint tone gun that will give them a pretty darn accurate mixing code or they can mix up the paint according to the door code and then "adjust" it to match the fade.
In the end you can't expect an exact match no matter where you go or what paint you get. The best you can do is get it as close as possible.
Old 07-09-2012, 11:25 PM
king-david king-david is offline
king-david has a very good reputation on FTE.king-david has a very good reputation on FTE.king-david has a very good reputation on FTE.
Ugh.. thats not encouraging. Both of the rear doors on my Ex are rusting under the trim and they'll need sprayed soon. I have an 02 Silver, hopefully they worked out the paint issues by then.
Paint code for dark gray cladding? sccamper Excursion - King of SUVs 5 03-13-2016 09:37 AM
paint code and color name arrowheadfred 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-22-2011 09:10 AM
Color Code lazerus 1967 - 1972 F-100 & Larger F-Series Trucks 10 02-27-2011 02:51 PM
what color vettman80 Excursion - King of SUVs 6 03-19-2010 04:48 PM
Need paint color code or brand desertt5 Excursion - King of SUVs 4 12-22-2009 10:58 AM
Tags
2006, code, color, excursion, ford, paint
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
