Help with front lower control arm replacement - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 06-21-2012, 07:13 AM
abcfisher1 abcfisher1 is offline
abcfisher1 is starting off with a positive reputation.
Need instructions on lower control arm replacement. Vehicle is RWD. I have already replaced the upper. Just a little nervous about the spring on the lower arm. Any help would be appreciated.
Old 06-21-2012, 11:48 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
You will need a coil spring compressor tool that you can borrow from almost any discount parts store. Good luck with the job.
<table width="95%"> <tbody> <tr> <td> SECTION 204-01A: Front Suspension — 4x2
</td> <td align="right"> 2000 Expedition/Navigator Workshop Manual
</td></tr></tbody></table> REMOVAL AND INSTALLATION
<hr> Arm —Front Suspension, Lower
<table border="1" cellpadding="3" cellspacing="0" width="50%"> <caption>Special Tool(s) </caption> <tbody> <tr valign="top"> <td></td> <td valign="top">Coil Spring Compressor
204-D001 (D78P-5310-A) or equivalent </td></tr> <tr valign="top"> <td></td> <td valign="top">Pitman Arm Puller
211-003 (T64P-3590-F) </td></tr></tbody></table> Removal
  1. WARNING: The electrical power to the air suspension system must be shut off prior to hoisting, jacking or towing an air suspension vehicle. This can be accomplished by turning off the air suspension switch located in the RH kick panel. Failure to do so can result in unexpected inflation or deflation of the air springs, which can result in shifting of the vehicle during these operations.
    Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. CAUTION: Do not use heat to loosen a seized wheel nut. Heat can damage the wheel and the wheel bearings.
    Remove the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Remove the brake disc shield. For additional information, refer to Section 206-03 .
  1. Remove the upper shock absorber nut and washer.
  1. Remove the front shock absorber (18124).
    1. Remove the two nuts.
    1. Remove the front shock absorber.
  1. Remove the brake hose bracket screw and bracket from the front suspension lower arm (3079).
  1. Remove the front stabilizer bar link nut.
  1. Using the Coil Spring Compressor, compress the front coil spring (5310).
  1. Remove the lower ball joint castle nut.
    1. Remove and discard the cotter pin.
    1. Remove the castle nut.
  1. Use the Pitman Arm Puller to separate the lower ball joint from the front wheel spindle (3105).
  1. NOTE: The front suspension lower arm nut must be installed in its original position.
    Index the front suspension lower arm nut.
  1. Remove the front suspension lower arm and front coil spring.
    1. Remove the two front suspension lower arm nuts.
    1. Remove the two front suspension lower arm bolts.
    1. Remove the front suspension lower arm (3078) and front coil spring.
Installation
  1. Install the front coil spring into the front suspension lower arm.
    1. Position the front coil spring on the front suspension lower arm.
    1. The spring must cover the first hole.
    1. The spring must be visible in the second hole.
  1. NOTE: Install the front suspension lower arm nuts in the original position.
    NOTE: The front suspension lower arm caster split adjuster is for production use only. Do not adjust.
    NOTE: The forward front suspension lower arm nut must be tightened first while the control arms are held at the curb position ride height.
    Install the front suspension lower arm.
    1. Position the front suspension lower arm and front coil spring.
    1. Install the bolts and nuts.
  1. Install the lower ball joint castle nut.
    1. Install the castle nut.
    1. Install a new cotter pin.
  1. Install the front stabilizer bar link nut.
  1. Remove the Coil Spring Compressor.
  1. Install the front shock absorber and the shock absorber lower nuts.
  1. Install the upper shock absorber nut and washer.
  1. Install the brake hose bracket screw.
  1. Install the brake disc shield. For additional information, refer to Section 206-03 .
  1. WARNING: When a wheel is installed, always remove any corrosion, dirt or foreign material present on the mounting surfaces of the wheel or the surface of the wheel hub, brake drum or brake disc that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the wheel nuts to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub mounting surface.
  1. NOTE: If equipped with air suspension, reactivate the system by turning on the air suspension switch.
    Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Inspect and adjust the front end alignment. For additional information, refer to Section 204-00 .
Old 06-22-2012, 08:12 AM
Thank you Moto Mel!
Fortunately I already own a coil spring compressor so I will use it this weekend to do the job. I replaced the entire upper arms this week (MOOG problem solver)and I noticed the OE drivers side ball joint boot was torn and the joint was clicking but I still hear a click when I turn so I suspect the lower ball joint is shot as well. I REALLY appreciate the instructions you posted. I am no mechanic but I will try just about any repair with a set of good instructions like these.
Thanks
Old 06-23-2012, 12:50 PM
BAD RONALD BAD RONALD is offline
BAD RONALD is starting off with a positive reputation.
Don't know what you are working on. The '97-'03 lower ball joints can be separated and are replaceable independently . Haynes manual says otherwise, but I did mine last week. Less work and $ than doing the whole control arm. Pointing this out because you said you had ball joint wear with no mention of control arm problems.
Old 06-23-2012, 07:53 PM
Thanks for the reply Ronald. I just finished the job. I found
the rear of the arms were severly dry and cracking and the ball joint boots were riped. The ride is much better now. The truck is a 2001 Navigator RWD and has close to 200k miles. The job was ok but I had to go buy a 24mm deep socket to get the rear bolt nuts off in the middle of everything. Took me all day but Im happy. I will get an alignment on Monday and celebrate my saving over the stealership!
Old 06-23-2012, 08:31 PM
Moto Mel's Avatar
Glad to hear that the job came to a satisfactory conclusion. For an alignment you might want to consider a Firestone tire store to get the Lifetime warrantee. I take my Navigator 4WD in every 6 m onths for a check up. It's a little pricey the first time but it pays in the long run, if your Navigator is a keeper.
Old 06-23-2012, 09:29 PM
Thanks again for your help Moto Mel.
Old 06-24-2012, 09:17 AM
Quote:
Just got my alignment done at the local Firestone on Monday. Very nice guys over there and normally aggressive salesmen. I'm sorry that they never mentioned lifetime alignment, I think I would've paid the difference. Maybe the manager can still be talked into the deal.
Thanks for the heads-up.
Old 06-24-2012, 10:55 AM
Moto Mel's Avatar
I'm sure the manager can make the adjustment and in my opinion it's worth the extra money to have an expert check the alignment as well as advising of any parts that will need replacement in the not too distant future. The one I go to has no problem with my doing the part(s) replacement and bringing the truck in for an alignment check/adjustment. I always give the tech a tip as that makes the reception I get pretty nice. On top of the value of knowing that my truck is in good condition you rarely know you need an alignment until your tires are badly worn and they are getting damned expensive lately.
Old 06-24-2012, 02:53 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Moto Mel, when they check your alignment, how do they keep the LLS from kneeling when its on the rack and they exit the vehicle to do the alingment?
Old 06-24-2012, 04:27 PM
Moto Mel's Avatar
I was in the truck and they opened the door and shut off the air ride while it was running and before going on the rack. The tech also checked the ride heigth before he worked on it.
Old 06-24-2012, 08:26 PM
Thanks Mel.
Sounds like your alignment shop is on the ball
I had my Navigator re-aligned.
Now the "CHK AIR SUSP" light comes on within 5 minutes of start up.
Pulled a C1725.
Haven't had time to look at it yet............
Old 06-24-2012, 09:18 PM
Moto Mel's Avatar
Quote:
Originally Posted by pdqford View Post
Thanks Mel.
Pulled a C1725.
Check your ride height sensor and the electrical connection at the sensor as well as searching for any cut or shorted wires in that system.
Quick question of size-lower control arm sockets needed. Archion 2004 - 2008 F150 0 05-30-2015 09:52 PM
Does anyone know how to replace pitman arm & idler arm Big Norm 1997 - 2003 F150 4 11-15-2014 09:53 AM
'99 Lower control arm bushings Moto7387 1997 - 2003 F150 2 11-13-2010 08:28 PM
98 4wd f150 ball joint replacement jadams1978 1997 - 2003 F150 3 11-10-2006 01:41 PM
help-- bolt stuck in lower control arm- rear axle bink_hawk_hauler Aerostar 5 03-07-2002 12:18 PM
Tags
2006, arm, arms, bad, bolt, bolts, control, escape, f150, ford, front, lower, pic, replacement, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
