Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-20-2012, 08:06 PM
Badbeny Badbeny is offline
Garage is empty, add now
Badbeny is starting off with a positive reputation.
CEL help
so i have a 1990 f350 with a 460 and a e4od i bought the truck a year ago it needed a new transmission. i noticed while the old transmission was in the cel light would quickly blink and turned off. so i replaced the transmission with one that was rebuilt by ford. it works great and shifts like it should no hard shifts or anything but the cel light would still blink i was thinking it could be the torque converter as when going up some hills itll go into a lower ger so higher rpms then it seems like it bounce around through the gears and depending on how hard the acceleration is the cel light is on. ive tried to pull codes and theres nothing at all. i want to get this problem fixed so any help will be appreciated
heres a video of the cel light blink truck is in park
this is while driving the truck you can see rapid changes in the rpms sorry its shaky
  #2 (permalink)
Old 06-21-2012, 11:04 AM
norfolknova norfolknova is offline
1992 Ford F-250
norfolknova is starting off with a positive reputation.
I just recently bought my truck and got a pretty good deal on it because the previous owner was told the trans or torque convcerter was bad. So I bought it, it was doing the exact same thing as yours. After searching several forums the concensus was to replace the Throttle position sensor. I figured what the heck, for $40 I will try it. No more random shifhing of the transmission. If I were you I would give it a try. As for the CEL mine does the same thing and I was told todo a key on engine running code check. But I have been too busy at work and it is too hot out to worry about it as my F250 is not my daily driver. And when you are buying the TPS also pick up a ne throttle body gasket as you have to pull it off the intake to change the TPS
Matt
  #3 (permalink)
Old 06-21-2012, 11:22 AM
Thanks matt I'll give it a try this weekend and let you know my final results
  #4 (permalink)
Old 06-21-2012, 08:01 PM
so i switched out the tps and took the truck for a drive and no cel. thanks for the help matt
  #5 (permalink)
Old 06-21-2012, 08:04 PM
1992 Ford F-250
glad it worked out. Like I said $40 sure beats $1500. So i take it it also cleared up the random shifting?
matt
  #6 (permalink)
Old 06-21-2012, 08:30 PM
yup. no more random shifts feels like it has more power through out every gear and itll actually stay in overdrive. sure does beat 1500
Tags
cel, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
