Installed the RR HPX line.
06-20-2012, 07:34 PM
and got rid of the loud valve train tick on number 6 or number 8 cyl. Idle has smoothed out and the 7.3 sounds allot better. Glad I did it.
Riffraff Diesel: Riffraff SS HPX 94-97
06-20-2012, 08:04 PM
If they work that well, I may do one too! You can add it to your sig now
06-20-2012, 08:42 PM
on
I did the hpx line and the 140 idm at the same time, and that smoothed out my idle a little bit.
06-21-2012, 12:01 AM
on
Quote:
Originally Posted by
stainlessstroker95
I second that motion.
06-21-2012, 01:12 AM
My HPX smoothed out my idle a little bit. It wasn't bad, but it was a little annoying.
06-21-2012, 02:24 PM
on
Just make sure you watch the fittings. Some of them are known to blow out blowing 600-3,000 PSI of oil out under the hood.
06-21-2012, 02:28 PM
mjonesjr
True if you install incorrectly.
I've known of guys making their own and having that problem mostly.
06-21-2012, 10:21 PM
I've got one on my truck and it smoothed out the engine quite nicely. Make sure you put new o-rings on it if you need to remove it for any reason.
06-22-2012, 06:15 PM
on
Does this fit in a stock valley with all the stuff in there?
06-22-2012, 06:20 PM
on
06-22-2012, 08:01 PM
mjonesjr
Is that from experience ?
06-22-2012, 11:26 PM
When I get some other things done, I'm gonna put one on my truck. I'd like to smooth it out a little, especially at idle. It's got that "blat blat blat blat" idle.
06-23-2012, 12:33 AM
Im glad im not the only one feeling that.it is not a miss just really an uneveness.next time i order i AM getting that! Thanks for the heads up!
Dang.i order any more frim riffraff i better send the wife some flowers or something.haha
06-23-2012, 07:43 AM
Our trucks have a weak cylinder due to the oil pressure routing.
The only way to eliminate it is with HPX or dual HPOPs.
I really need one also.
I think I'll get one for the hell of it the next chance I have some buckaroonies.
BigRed1Ton
23
02-20-2016 02:04 PM
arkredneck
12-25-2009 08:53 PM
grams72
09-14-2009 04:17 PM
mjlewis
25
04-08-2007 10:15 PM
mexemo
03-06-2007 10:45 AM
73 ,
96 ,
authority ,
california ,
club ,
county ,
dual ,
hpx ,
install ,
king ,
oil ,
powered ,
powerstroke ,
regional ,
smf ,
sport ,
transit
