Accurate way to test Coolant/Antifreeze 50/50 mix
Thanks guys....
Ok so heres what I found with the testers I used the Chaslyn Small Anti-Freeze Tester, & the Prestone one. The Chaslyn I got all 5 ***** floting but the fifth one not as high as the others, the Prestone I got a +268 -45 reading on it.
Also I need to top it off about a 1/2 gal? was going to mix the Motorcraft Coolant and Distilled water 50/50, but the Motorcraft I have is a open 3/4 full gallon thats about 5 years old, its been in sitting in the truck box all that time is it still good to use?
Also I tested it by draining about 1 cup, and by the expansion tank.
Thanks ~Gage~
Thanks ~Gage~
Thanks guys....
Thanks ~Gage~
Thanks ~Gage~
Annihilator
12-03-2004 08:21 PM
