How do I remove the tailgate assist handle and replace the lid with a normal - Ford Truck Enthusiasts Forums
Old 06-20-2012, 03:22 PM
peety37 peety37 is offline
peety37 is starting off with a positive reputation.
I though I would like the tailgate step and assist handle. They are always in the way and I want to get rid of the handle but keep the step if possible. Can I remove the plastic tailgate cover, pull the hande and re-install a metal tailgate cover.
If not, Does anyone want to swap a tailgate. Its red, has the back-up camera and, no dealer markings and in excellent condition.
Thanks
Old 06-20-2012, 04:38 PM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
I did exactly what you asked about. It was also for the same reason.
Remove the plastic tailgate cover. You will find 6 torx screws holding the handle in place, remove them, and do what you wish with the handle. Next you will need to cover the opening with the normal access panel from a non step tailgate. You can order if from the dealership for around $80, or you can find one off of a 1999-2012 pickup for probably a lot less. If you go the used route you will be one step ahead of me and have a painted one. You will also need shorter screws to attach the new access panel to the tailgate. I got shorter screws at Lowes because they were cheaper than the dealership. Hope this helps.
Old 06-20-2012, 05:39 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
^^^^^^ Great post sir, reps sent.
This is a great example of how FTE should work. A person asks a question and the answer appears without the added drama of "you should have searched that" or, "that's a dumb question".
I like it!
Old 06-21-2012, 11:38 AM
edlEBBY's Avatar
edlEBBY edlEBBY is offline
edlEBBY is starting off with a positive reputation.
couldn't agree more
Old 06-21-2012, 03:21 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Quote:
Originally Posted by awq134 View Post
... or you can find one off of a 1999-2012 pickup for probably a lot less...
A whole lot less if you shop around the local Lowe's parking lot for it...
Good advice. I plan on doing this some day. That handle is a PITA.
Old 06-21-2012, 05:12 PM
tseekins's Avatar
I wish I had gotten the man step now, these trucks are so flippin high that I have a stool in my garage to step up into my bed.
Old 06-21-2012, 05:36 PM
awq134's Avatar
all of the guys at work laugh at the man step and pull it out like a spoiler with the tailgate closed, but i don't know what i did before i had it. I use that step all of the time.
... and tseekins, thanks for the rep.
Old 06-22-2012, 07:27 AM
Thanks for the info. I thought it was possible. I'm looking now for a new cover
Old 06-22-2012, 02:16 PM
Nogyro Nogyro is offline
Nogyro is starting off with a positive reputation.
Same here. Love the step but hate having the handle there. Nine times out of ten all I do is drop the step anyways, and I sure miss the flat tailgate to work off. My handle will be coming off as well.
Old 06-22-2012, 02:52 PM
ALLDATAdiy INFO ALLDATAdiy INFO is offline
Former Vendor
ALLDATAdiy INFO is starting off with a positive reputation.
Great Idea! Thanks!
Old 06-22-2012, 03:35 PM
DIXIEDOG1's Avatar
DIXIEDOG1 DIXIEDOG1 is offline
DIXIEDOG1 is gaining momentum as a positive member of FTE.DIXIEDOG1 is gaining momentum as a positive member of FTE.
When folks laugh at your man step it is just a sign of step envy....there are two types of people in this world.....the type that have the tailgate step and the type that wish they did too.
I've thought about swapping my cover out as well, the tailgate step is flat out awesome...I also really like the box access steps on the side too.
Old 06-22-2012, 04:57 PM
awq134's Avatar
if you do go with the used access panel i hope you have better luck at the salvage yard than i do. I asked them if they had a tailgate from a 1999-1011 and they looked at me like i was retarded. they said that the part numbers weren't going to be the same. I tried to explain to them that it wasn't an issue, as i have taken measurements and any of those years would work. I think they just didnt' want to have to search for each year's model to see if they had one.
Removing the tailgate Handle? cr2crf 2009 - 2014 F150 2 07-09-2013 05:50 PM
Tailgate Step Delete sgrol 6.7L Power Stroke Diesel 12 06-18-2012 03:29 AM
Tailgate step & handle??? ackeiyword 2009 - 2014 F150 27 05-18-2012 11:41 AM
2012 Stainless Steel Full Tailgate Protector Pitt4212 1999 to 2016 Super Duty 0 02-07-2012 07:19 PM
Line-X and SD 08 Tailgate step question 250kr Aftermarket Products 7 01-12-2008 11:22 PM
Tags
03, assist, expedition, f100, f150, ford, handle, liftgate, removal, replace, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
