HELP - 99-03, 7.3 POWERSTROKE / LANDCRUISER - Page 5 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #61
Old 07-09-2012, 06:00 PM
BRAD ROLSTON BRAD ROLSTON is offline
BRAD ROLSTON is starting off with a positive reputation.
Can anyone please help me with the exact weight of a 7.3l engine, ZF6 Transmission, and Transfer case. Need this quite urgently for a shipping quotation.
  #62
Old 07-09-2012, 07:19 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
The dry weight of a ZF6 is 235 Lb. Sorry don't have the transfer or engine info, but will see if I can find some.
  #63
Old 07-10-2012, 03:46 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
around 1000lbs on the engine
  #64
Old 07-10-2012, 03:55 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
That's about what I always say too, here is some information
7.3L Power Stroke Specs
  #65
Old 07-10-2012, 08:47 AM
Texas Chain Ring Texas Chain Ring is offline
Texas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to behold
Quote:
Originally Posted by Rpayne View Post
Here is a link to a build up where a guy put a 7.3 in a IH Scout 80. If one will fit in a scout im sure with your determination you can get one into your landcruiser. A Scout 80 followed me home - Page 6 - Binder Bench
Page 6 is where he actually starts the engine install. He uses a 96 7.3 with an attached ZF 5 speed. Just thought it might help you get prepared for some of the small things that might come up during your build.
If the engine offers youve already had dont work out, my only idea would be to search craigslist in the area of your shipper in CA for someone parting out a ford that you could get the whole engine, trans, transfer case and all wiring and other small things from and have them remove them and take them to your shipping contact. And maybe someone here would be close enough by to go check it all out for you first. If you dont have any other luck, I'll keep an eye out for one here in TX.
I never would've believed that possible had I not seen it with my own eyes. What an awesome build!
  #66
Old 07-10-2012, 05:18 PM
Thanks everyone
Got it at 920lb for the motor and 235lb for the ZF6 - nothing yet on TC
  #67
Old 07-10-2012, 08:27 PM
Im only guessing here from when I took mine out but I would say around 150lbs. for the TC
Hey Brad - that 920lbs. is that a complete motor ???
  #68
Old 07-10-2012, 10:07 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
when i shipped a zf6 and TC and some hardware it was 410lbs.
  #69
Old 07-12-2012, 09:12 PM
Nkelly's Avatar
Nkelly Nkelly is offline
Farkall User
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Now a 7.3 in a Nissan GU Patrol wagon or tray back would be a top match would love to do that..
  #70
Old 07-14-2012, 08:26 AM
More confusion........
Have decided to go with a Garrett GTP38R Turbocharger.
Now, the Garrett agent in SA has never heard of it, but can supply me with any of the following units:
GT3582R with AR63 or AR82 turbine housing
GTX3071 with AR64 or AR86 turbine housing
GTX3582R with AR63 or AR82 turbine housing
Are any of these units the same as a 38R.?
Alternatively, is the there a Tubonetics unit that is the same as a 38R
www.turboneticsinc.com .?
Or perhaps another ball bearing turbo of the same quality and size of the 38R.?
  #71
Old 07-14-2012, 07:18 PM
Have you spoken to these guys Brad. Just done a google search and they have made several inquiries re importing Garret GTP38R turbos. There would have to be some one over there that stock em.
Home VR DIESEL
  #72
Old 07-15-2012, 04:14 PM
Thanks for that - will give them a call first thing in the morning. The other so called "turbo specialists" down here ask me what I've been smoking when I give them the part #..............
  #73
Old 07-16-2012, 06:27 PM
The last of my Autometer gauges arrived today. Is it possible to remove the cluster panel from the vehicle, and have only the Autometer gauges installed.?
  #74
Old 07-17-2012, 01:36 PM
Also - what is the quality of Borg Warner Tubo's...........
  #75
Old 07-19-2012, 05:34 PM
Have been looking at a Bell ZQSSB Turbo. Going to be around the same price as a 38R. Any help here............???
1959 Ford F500 Charles Melck 1957 - 1960 F100 & Larger F-Series Trucks 2 11-13-2014 08:40 PM
Tags
73, article, case, dashboard, display, dowel, ford, forums, groups, killer, pin, powered, powerstroke, stroke, support, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
