HELP - 99-03, 7.3 POWERSTROKE / LANDCRUISER - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 06-24-2012, 11:07 PM
Rpayne Rpayne is offline
Rpayne is starting off with a positive reputation.
Here is a link to a build up where a guy put a 7.3 in a IH Scout 80. If one will fit in a scout im sure with your determination you can get one into your landcruiser. A Scout 80 followed me home - Page 6 - Binder Bench
Page 6 is where he actually starts the engine install. He uses a 96 7.3 with an attached ZF 5 speed. Just thought it might help you get prepared for some of the small things that might come up during your build.
If the engine offers youve already had dont work out, my only idea would be to search craigslist in the area of your shipper in CA for someone parting out a ford that you could get the whole engine, trans, transfer case and all wiring and other small things from and have them remove them and take them to your shipping contact. And maybe someone here would be close enough by to go check it all out for you first. If you dont have any other luck, I'll keep an eye out for one here in TX.
  #32
Old 06-24-2012, 11:14 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
wow, thats going to be front end heavy. IH scouts used a little 4cyl perkins diesel that was very economical.
  #33
Old 06-25-2012, 10:11 AM
BRAD ROLSTON BRAD ROLSTON is offline
BRAD ROLSTON is starting off with a positive reputation.
If that can work, my Cruiser shouldnt be too much of a problem......
  #34
Old 06-25-2012, 04:26 PM
Red_Chili Red_Chili is offline
Red_Chili is starting off with a positive reputation.
Hey Brad, your post caught my interest. I am a Toyota builder guy.
And a BIG fan of the Toyota drivetrain components, even given their limitations (which can be built around using aftermarket modified parts, and not a lot of them).
My drivetrain is in part Landcruiser. I am running a supercharged 3.4L 24V V6 Toy motor and 86 turbo tranny, 20 fwd speeds, 4 reverse, 4.88 gearing, modified birfields in the front, full floater in the rear, and without issue. My truck is lighter than your SA cruisers in all likelihood but not by a lot (note the armor).
That said, a 7.3 would take out my drivetrain in a bushfire second and with pretty much the same effect.
The 4BT is indeed a very popular conversion and a worthy one. That's the way to go mate.
Although... hmmm... a 7.3L with a PSD drivetrain under a Cruiser... hmmm... HMMM...
(One of our clubmembers put an FJ45 body on an FZJ80 chassis and ended up with a fantabulous truck, reliable, strong, luxurious ride, beautiful paint, on 44s, that will do anything he wishes... so it can be done).
Good luck!
  #35
Old 06-25-2012, 05:40 PM
Red Chilli
Many thanks - wish my Cruiser could do that.
If you have any other info, please send it along....
  #36
Old 06-25-2012, 05:41 PM
Another Question
Is there a source where I can get complete manuals, pictures, diagrams, DVD's, and any other info on the 7.3 and the ZF6 and transfer case. As comprehensive as possible - all wiring, censors, fuse boxes etc. - Absolutely Everything......?
Would like to have any hard copies shipped with my 1st engine and transmission...
  #37
Old 06-25-2012, 06:05 PM
honeydew honeydew is offline
honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.
Here is some general stuff you can print out:
DTS Articles - Coffee Table Books
Ebay is probably one of the best places to pick up hard copy manuals.
Emissions diagnostic manual is a good one to get for the year engine you end up buying.
Here is another great online resource where you can print stuff:
ALLDATAdiy.com Leading Source of Factory Automotive Repair Information
Can't beat this for a wiring diagram, take the file to the local engineer to print:
http://www.ford-trucks.com/forums/11...e-diagram.html
  #38
Old 06-25-2012, 06:09 PM
Thanks again honeydew.....
On my way there now.
Anything else you can think of, please send it on.
  #39
Old 06-25-2012, 06:25 PM
That_Guy's Avatar
That_Guy That_Guy is offline
That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.
Quote:
Originally Posted by Christof13T View Post
p.s.
i have to ditto on the powertrain holding up to the stroker...
the badassness you witnessed in that truck was not just the motor...
the 4r100 is a marvel all into itself. to make all the rediculous torque from the 7.3 pull an 11,000lb truck hard enough give you the giggles requires a whole lot going on behind the scenes... also...
suspension...
these things weigh half a ton.
what will that do when you hit the muck/sand with your wheelbase?
need to change out front suspension to beef it up
been thinking about stuffing one in my 82 f150... keep us posted eh?
xtof
The 4R100, wasn't ford best design. Some of them last for a while but some don't make it to 100k in a stock truck.
I think your referring to the motor, but IIRC it weights 1400 lbs dry.
  #40
Old 06-25-2012, 10:11 PM
rustyculley rustyculley is offline
rustyculley is starting off with a positive reputation.
Brad, I can lay hands on a running F250 that was wrecked recently. It has an auto trans, but otherwise everything else you need. I'm not far from Gator so if you get some stuff from him it might be that shipping would be easier too.
  #41
Old 06-26-2012, 01:21 PM
That Guy
What is a 4R100.?
rustlculley
If possible, please get me price and any info, pictures etc. Will need complete motor with all wiring, sencors, ignition etc.
Still having a hard time locating a ZF6 and transfer case.......
  #42
Old 06-26-2012, 01:33 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
4r100 is the auto trans the ZF6 is the 6speed trans.
and here is a PDF if the shop manual
Workshop Manuals - 1999 SD 250-550 - PowerStrokeNation : Ford Powerstroke Diesel Forum
and there is not that much to get them to run just stuff the computers in the dash and the rest is easy.
  #43
Old 06-26-2012, 04:34 PM
Thanks snakedoc- on my way there....
  #44
Old 06-26-2012, 10:12 PM
I'll check into it for you. May take a couple of days.
  #45
Old 06-26-2012, 11:39 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Quote:
Originally Posted by honeydew View Post
No headers for this engine since it has a turbo but there is at least one company offering a S/S option for an aftermarket turbo mount kit: Untitled 1
I'm not aware of any S/S exhaust manifold options for the 7.3, there are some available for the 5.9 cummins though.
In the sake of full disclosure, SS headers for the 7.3 do exist and can be purchased commercially.
7.3l Tubular Manifolds
They do offer a performance increase, but the biggest noted change is the sound of the truck. You can youtube it for more info.
1959 Ford F500 Charles Melck 1957 - 1960 F100 & Larger F-Series Trucks 2 11-13-2014 08:40 PM
Tags
73, article, case, dashboard, display, dowel, ford, forums, groups, killer, pin, powered, powerstroke, stroke, support, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
