scan gauge II
The ScanGaugeII is very easy to install AND the best $160 I've spent on my '05. Without it, I would've never known how far apart my ECT/EOT deltas were. And that could've been catastrophic if I had've kept towing my 5er without changing my Oil Cooler. Just plug it into the OBDII port at the bottom of the dash right above the gas pedal, follow the directions for loading the codes and you're good to go.I velcroed the gauge on the plastic part of the dash right underneath the headlight switch.
Jeff
<!-- / message -->
Jeff
<!-- / message -->
Here is the how to programming video over on Youtube
You can get the codes on the SGII site and some you
can get from people on here
Sean
Scangauge II Xgauge entering - YouTube
Sean
The SGII comes with some preprogrammed gauges. You have to program the other 24 that you want and they all have positions they can be programmed in. The SGII will start with X gauge #24 and display them from #24 down to #1 AFTER the preprogrammed gauges. If you program your Xgauges in alphabetical order (starting with Xgauge #24) it's easier to find them.
For example: Xgauge #24 would be boost, #23 would be EOT, #22 would be FICM, #22 would be MAP.
I think you'll understand what I mean after you start trying to program it.
Hey guys Im a new 6.0 owner and was wondering about the H&S mini maxx tuner and SG2. Does the H&S have the ability to monitor the same sensors and gauges as the SG2? I was seeing if by having the H&S it would keep me from having to buy the SG2 as well. Thanks for the help before i make these purchases!
Odds are the SGII will get alot more gauges than the tunner you talk about
I haven heard of the H&S tunner you mention but SGII sees all the PCM sees on the moter and some trans stuff
For what it is SGII is Best Deal going IMO
The next best scanner would be AE with Ford Enhanced Bundle
The SGII is the way to go for the money IMO
Yes that SCT tunner should work
Get a tune for a NON STUDDED truck unless you have ARP headstuds
#28
Yes^^^^ or Maybe Eric or Matt the custom tune writters may help to IDK
And would be a good Idea to start a new thread on tunes the Boys can give you better help that way
I dont really keep up with the tunner & Tunes end of things
#29
#30
427 fordman
36
08-13-2010 08:16 AM
