Zoodad - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Zoodad
Old 06-20-2012, 12:46 AM
Bvill01 Bvill01 is offline
Bvill01 is starting off with a positive reputation.
Zoodad
I have a 2001 7.3 stock and wanting to cut a zoodad mod do they work or should I go with a 6637 filter I think I have the wright number ?
Old 06-20-2012, 12:58 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Really they will pair with each other, so it's not a one or the other kind of thing. Not sure really how much the Zoodad actually effects it though. And yes the filter is commonly called the 6637, Tymar, Kwik, BHAF mod, etc.
Riffraff Diesel: RDP 6637 Filter Kit
Riffraff Diesel: 6637 Replacement Filter
Old 06-20-2012, 11:37 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
I just drilled three holes to kinda of match up with my AIS intake snorkel.
Still like that now. Never had to open it up. Even if you go with a 6637
it is still good to get some cooler air past the header panel.
Old 06-20-2012, 11:45 AM
magicsac1366's Avatar
magicsac1366 magicsac1366 is offline
magicsac1366 is starting off with a positive reputation.
I did 2 2.5" holes like above, then used my 4.5" cut off wheel to open it up in between. Works great, using my air temp gauge, it really helps cool the air down after your truck sits. Like if you're at the store and its 85* out, when you start the truck its like 115* under the hood. Doing the zoodad cools it down a lot faster.
Old 06-20-2012, 12:04 PM
microdevil45's Avatar
microdevil45 microdevil45 is offline
microdevil45 is gaining momentum as a positive member of FTE.
Quote:
With this in mind do you guys think it would be beneficial to do this to the other side as well. Put cooler air in the entire engine compartment?
Old 06-20-2012, 12:26 PM
Keep in mind the fiberglass there also helps direct air over the innercooler, rad, and condenser. So you don't wanna take away from that. If you want to cool off the engine bay, maybe work some 2008 fender vents in?
Old 06-20-2012, 12:29 PM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
Quote:
Those panels are in place to force air through the various heat exchangers. Assuming your radiator, CAC, transmission cooler, and AC condenser are functioning properly, defeating those panels is probably going to do more damage than good in the grand scheme of cooling.
Old 06-21-2012, 08:25 AM
Thanks... Boy am I glad I didn't do that one. I would have to call it the OH ******dad....
Old 06-21-2012, 09:35 AM
USAF CCM's Avatar
USAF CCM USAF CCM is offline
USAF CCM has a good reputation on FTE.USAF CCM has a good reputation on FTE.
I enlarged my intake air holes some years back. I highly recommend putting 1/4 wire mesh over this, if you have nesting birds where you live. Those suckers built a huge nest in the intake plenum that ended up underneath my AIS filter once I started the truck after it sat for awhile.
Steering Stablizer ZooDad 6.7L Power Stroke Diesel 4 11-22-2015 08:18 PM
What is the Airaid Zoodad Mod? rayezra 6.0L Power Stroke Diesel 3 10-25-2009 07:24 AM
Zoodad?? Powerstroke-7.3 1999 - 2003 7.3L Power Stroke Diesel 18 04-23-2009 10:05 PM
Zoodad Mod WJC Excursion - King of SUVs 5 07-23-2008 11:33 PM
Zoodad Mod 10banger Modular V10 (6.8l) 2 10-27-2004 10:49 AM
Tags
6637, 6637tymarbhaf, dad, diy, upgrade, zoo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
