360 timing - Ford Truck Enthusiasts Forums
360 timing
Old 06-19-2012, 11:27 PM
Rivergreen74 Rivergreen74 is offline
Rivergreen74 is starting off with a positive reputation.
360 timing
Alright boys, down to the final steps!! My son and I have replaced the valve seals, lifters, pulled the intake, replaced water pump, fuel pump etc etc- Truck is a 74 f100 360, C6 and all original. Sticker says 3 degrees BTDC, is this the recommended timing or should it be higher? Thanks all.
Old 06-20-2012, 12:13 AM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
According to my Clymer manual, 69-72 FEs are timed at 6 BTDC and 73-75 FEs are to follow the timing indicated on the valve cover decal.
Congrats on your project getting ever so close...
Old 06-20-2012, 10:06 AM
Thanks, Right now it is around 8-10, seems to like it but I will take it down to 3 and see how she likes it. Only the interior, brakes, paint and a few other things left. Good thing we have another year or two :}
Old 06-20-2012, 11:32 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
The factory specs are geared more towards emissions than performance, FE's generally like 10-12 initial, so i'd leave it where you have it, or even bump it up slightly.
Just don't exceed 36-38 total or you risk detonation, do you know which advance slot your distributor is using? 10L 13L 15L etc?
Old 06-20-2012, 12:56 PM
No, to be honest I am not sure what that means. It is all stock and I put the distributor back so it was in the same location. It does have the optional duraspark ignition.
Old 06-20-2012, 01:28 PM
Those numbers are stamped on the advance slot (located under the distributors breaker plate), they tell you how much mechanical advance you have...
10L=20 degrees
13L=26 degrees
15L=30 degrees
Example: 10 degrees initial with the 13L advance slot (26 degrees mechanical) equals 36 degrees total.
I need to replace the 360 engine in a 74 F-250 highboy - what are my options? funfunstuie 1973 - 1979 F-100 & Larger F-Series Trucks 46 12-18-2016 03:46 PM
Help with timing set up on new 390 clydes 74 ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 07-23-2015 09:29 PM
1974 f250 360ci distibutor keeps dying. norts1138 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-30-2014 09:16 PM
360 won't star Blue Dog 74 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-03-2013 08:46 PM
360 AOD grizzweideman 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-18-2012 09:08 PM
Tags
1998, 360, ford, marks, ranger, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
