Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 06-19-2012, 02:31 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Horn Button and relay
I have gotten the lights and other wiring hooked back up, but have a question. From the laminated wiring diagram I bought, it seems the horn button is used to create a ground instead of power. I will be getting a relay at napa after work, but right now when I clip my test light to the positive battery terminal and stick the point into the white wire coming through the firewall (and I'm pretty sure is the horn wire), I get a light. I mean the white wire is already a ground, and so when I get the relay and wire it up I'm thinking the horn will sound continuously. Maybe something with the relay prevents this, or maybe my horn button is stuck in the 'horn honk' mode......
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #2 (permalink)
Old 06-19-2012, 02:55 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Gary, I think you should have a wire coming all the way down the center of your steering shaft through your steering gear box, that is grounded when you press the horn button. That wire coming out of your gear box goes to the relay, the power for the relay comes from the hot side of your starter relay (old system) third wire from horn relay goes to horn/s.
Maybe yours is deferent?
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #3 (permalink)
Old 06-19-2012, 03:52 PM
GB SISSON's Avatar
No, actually I think I'm the one that's mixed up. I remember seeing that wire, so I'll chase it down. Thanks, maybe I'll get it hooked up tonight after all. Actually there are 2 horns with a yellow crossover wire between them. Not sure if that was the factory deal.
__________________
  #4 (permalink)
Old 06-19-2012, 08:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Quote:
Originally Posted by theodore/teddy View Post
Gary,
There is an good chance of that being the case!
  #5 (permalink)
Old 06-19-2012, 10:32 PM
GB SISSON's Avatar
Hey, i might have chopped up and butchered the frame and axles and the floor, oh yeah and the dash and the seat and the front clip, and the driveshaft ...., but I never messed with the horn wiring. So I tested the horns after work and neither one worked. I had to take the covers off, and clean the points and readjust the nut, and now they blow like crazy. I painted them and mounted them with separate ground wires. Then I jumpered them together and hot wired them to the battery and got that 50's sound of really loud dual horns. Maybe tomorrow I'll make it to town for a relay, then I can wire them up for good. If I can't find the horn button wire in the loom, I'll just tap into it were it emerges from the steering box. I'm afraid I've done a lot of that......Wouldn't it be good to put an inline fuse in the horn circuit, since it feeds right off the battery?
__________________
  #6 (permalink)
Old 06-21-2012, 12:35 PM
GB SISSON's Avatar
Turns out the white wire was my right front blinker.....I tapped into the horn button wire right outa the steering box and cleaned the contacts under the horn button. Now the horn button makes my tester beep, so I know when I get a relay, it should work. I pity the next guy that has to chase this wiring .
__________________
  #7 (permalink)
Old 06-21-2012, 03:07 PM
Gary, I may understand your point!
I spent all day yesterday trying to rebuild my dash wiring, and I'm the goofball that has hacked, spliced, added, changed this wiring over the last 40+ years.
I think its right now just have to stuff it in there and tie into the rest of the nest I'm adding a tilt wheel column (Ford) with a 4way hazard switch in it, so we will see how it goes when its powered up
__________________
1959 F250 4x4
Wally
  #8 (permalink)
Old 06-21-2012, 05:31 PM
spurredon's Avatar
Just don't touch anything metal!
  #9 (permalink)
Old 06-21-2012, 11:12 PM
GB SISSON's Avatar
But my friends always said I was 'well grounded'. Not sure if that makes it better or worse........
__________________
  #10 (permalink)
Old 06-22-2012, 09:11 AM
Thats only bad if your nickname was Sparky!
__________________
1959 F250 4x4
Wally
Tags
1948, 1960, button, f1, ford, horn, install, napa, repair, st, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
