ford wants $200 for a fuel filler neck? i just need the inner hose
Had to pull the forward fuel tank to fix a leaky brake line. I got lazy and just cut the rubber hose going to the tank with a knife figuring I could just get a new one at the local parts store. Well it seems that there is a smaller hose inside of the larger hose. Went to ford and they said they don't just sell the hose (either hose) but only the whole "filler neck assembly" for $200-500. I almost fell out at the counter. Is there anywhere I can just get the rubber hoses?
So, just get rid of the inner hose and find a used outer hose? It looks like the tank already has a little breather line that comes off the top. I doubt enough air can get through that little line as the tank is filling up. Do I just enlarge that hose?
Yea, I guess it is called the midship tank. In all seriousness I'd rather just find someone with the two hoses instead of doing the mod. I guess I could do the mod, it's just not what I set out to do. Just wanted to drop the tank, fix the leaky brake line, then put the tank back with new tank straps.
The only decent "junkyard" around here is a Pick-n-pull. Really mad at them though cause it's a good 20 miles and when I called them to see if this95' F-250 on the webpage was a diesel or not the guy said "well come out here and see." Now that I think about it is the filler neck on the gassers the same?
