Drivetrain screeching noise - Ford Truck Enthusiasts Forums
Old 06-19-2012, 11:16 AM
BenS77 BenS77 is offline
BenS77 is starting off with a positive reputation.
Hey guys,
My truck makes a horrific screeching sound when it's loaded or pulling a small trailer (2000lbs) up hill. I discovered last night while I had it in drive, if I hold the brake and give it a little gas (like if you were trying to do a burnout) it will make the screeching noise as well. It won't break the rear wheels loose either, which makes me think it's down on power or the transmission is slipping.
My first thought is the transmission, but some searches on this forum describe U-joints or the carrier bearing as possibilities. The previous owner told me he replaced a U-joint just before I bought it, so I'm not ruling that out at all. Any ideas?
My truck specs:
1995 351 E40D 4x4 (manual transfer case & hubs), extended cab eddie bauer. 158k.
Old 06-21-2012, 11:51 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Not the ujoints.
If it were the bearing, that bearing would be HOT right after you hear the screech.
I think this could be the torque converter clutch or something else internal.
Start saving up.
Old 06-22-2012, 11:10 AM
batchman batchman is offline
batchman is starting off with a positive reputation.
If you get the screech when the truck is not moving, it's not the carrier bearing or u-joints etc.
Can you have someone stand next to the truck when you duplicate this, if the sound is from the front maybe it's a belt tensioner or idler pulley (not uncommon) or even A/C clutch (is the air on?).
Good luck,
- Jeff
Old 06-23-2012, 02:07 PM
I usually drive around with the air off, and it does have at least one idler pulley squealing when it's cold.
I'm pretty sure this is something transmission related. I guess I'll pull the codes on it and see if anything is there.
Old 07-02-2012, 05:51 AM
I took the liberty of checking both harnesses that run to the transmission. The one on the passenger side had oil in it. I cleaned off the connector on the harness and on the trans with electronic cleaner, then put on a bit of dielectric grease. I also did the same for the connector on the MLPS (or neutral safety switch as some call it).
I go for a test drive, and I've lost first and OD. Damnit!
This appears to be classic MLPS going bad symptoms, so I picked up a new one from napa. Installed it, and the truck has never ran better! First and OD is back, plus my original problem with the squealing seems to be better, it has more power and it will lay some rubber now in first gear. Rock!
I'll update this thread if anything else crops up or the issues return.
6.4L screech on initial take off. Busted Bones 1999 to 2016 Super Duty 5 03-31-2016 07:44 AM
Screeching/Grinding Noise coldy12 1999 to 2016 Super Duty 8 08-17-2015 03:56 PM
If you're bored IHateCommieCars 6.0L Power Stroke Diesel 18 05-24-2015 05:31 PM
loud screeching engine noise - NOT BELT ORIENTED stormblue 1968-2013 Full Size Vans 15 04-05-2015 02:49 PM
Screeching from pass side engin not belt or pullys Jbartley111 1999 to 2016 Super Duty 1 03-20-2015 06:00 PM
Tags
2005, car, case, f150, ford, rear, replaced, screeching, seal, sound, starting, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
