Spin on fuel filter and base part numbers? - Ford Truck Enthusiasts Forums
Old 06-19-2012, 11:27 AM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
I just did the Hutch/Harpoon mod and I do have a napa 3007 filter. I would like to upgrade to a spin on filter and base for prepump filtration. Anyone have part numbers for a napa filter and base? I am hoping I can find something local. Thank You!
Old 06-19-2012, 11:53 AM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
I use a Baldwin FB1311 base with a BF1212 filter. Napa's filter is a FIL3405 and their base is a FIL4770.
Old 06-19-2012, 06:14 PM
Thank you verry much. Exactly what I was looking for.
Old 06-19-2012, 07:09 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Ken, I use the same as you but how often should the filter be changed? Iv'e had mine on for a year now.
Old 06-19-2012, 10:01 PM
I would change it every 15-20k like your fuel filter.
Old 06-20-2012, 01:28 AM
Pitcrw6's Avatar
Thanks Ken, guess I need to go buy some filters.
Old 06-20-2012, 08:37 AM
Joe28443's Avatar
Joe28443 Joe28443 is offline
Joe28443
Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.
Where did you mount this filter?
Old 06-20-2012, 10:55 AM
Pitcrw6's Avatar
I have a longbed and I mounted mine one the inside frame rail about 3 ft behind the fuel pump and 1 1/2 ft in front of the fuel tank.
Old 06-20-2012, 12:53 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Quote:
if you have remnants of angle metal or c-channel, thin wall. WHere Rob mentioned, theres 2-already holes in the frame, to mock up ur metal to...worked perfect for me.
Old 06-20-2012, 02:21 PM
Joe28443's Avatar
Joe28443
Thanks, I may look into that
Old 06-20-2012, 06:59 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
I used Napa Part numbers
# FIL 4770 Filter base
# FIL 3244 Fuel Filter
Made my own bracket
Old 06-22-2012, 07:13 AM
bobbyrjw's Avatar
bobbyrjw bobbyrjw is offline
bobbyrjw is gaining momentum as a positive member of FTE.bobbyrjw is gaining momentum as a positive member of FTE.
Made my own bracket
I have been doing my own maintenance for many years and have NEVER thought about putting the date/mileage on the filter
Takes the guess work out of "when did I change that last?"
Old 06-30-2012, 12:11 PM
Thanks again for the part numbers. Here is what I did. Not fancy I just welded together some scrap I had lying around.
I was afraid it was going to hang too low butt it should be fine.
Old 06-30-2012, 12:48 PM
Nothing wrong with that mount. Simple and effective! Doesn't get much better than that! Looks great too!
Old 06-30-2012, 07:53 PM
Bonanza35 Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Good job. I still need to do mine. Easy but dose the job.
Chet
534 oil filter swap deere81 401, 477, & 534 SD Engines 1 01-28-2017 06:07 PM
what fuel filter brand are you useing corman146 6.0L Power Stroke Diesel 14 10-13-2015 07:44 PM
thinking of using a spin on fuel filter on a76 f100 standardtransonly Fuel Injection, Carburetion & Fuel System 1 09-25-2014 11:56 AM
Napa 3405 fuel filter? Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 14 12-27-2012 08:59 AM
E fuel question 96ford250 1994.5 - 1997 7.3L Power Stroke Diesel 58 08-07-2012 06:35 PM
Tags
60, base, conversion, coolant, diy, filter, filters, ford, fuel, gas, oil, powerslot, ranger, screw, spin, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
