1952 original frame and motor color? - Ford Truck Enthusiasts Forums
Old 06-19-2012, 10:57 AM
sac52's Avatar
sac52 sac52 is offline
sac52 is starting off with a positive reputation.
I tried to search for my answer but had no luck so I am gonna ask. I know you guys will know.
What was the original color for the frame and the motor for a 1951 and/or 52 f1. I've been told the engine (V8) was a bronze...is that true? Also when I stripped my frame and the cab for on my 52 it was a green, kind of like an OD green. It was on everything...frame, axles, underside of the bed wood and even underside of the cab and up onto the firewall, which was not painted over by the PO with purple.
I am considering going Dearborn stock with my next project and was hoping to start with the right colors underneath.
Old 06-19-2012, 01:40 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Black frame and suspension.
Old 06-19-2012, 08:51 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Engine color in '52 is Lincoln green. Detroit Diesel Alpine Green is said to be a close match. So is Krylon #2007. If your aim is to merit a Dearborn Award from the EFV8 Club, I'd suggest the Lincoln green sold by Bill Hirsch. Comes in spray cans, but is expensive. The truck engines in '51 were red, not the bronze used on cars. I've not researched the shade of red, but I think it's the same red used from 48-51.
Ilya has you covered on the black frame components. On mine I've seen that it was a shiny black, but not too shiny. Stu
Old 06-19-2012, 09:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Quote:
Eastwood Chassis Black looks the best IMO. Not gloss, not matte, "just right" and it is a dream to spray.
Old 06-19-2012, 11:26 PM
51PanelMan's Avatar
What colors were the flathead V8s painted in 52? Was it the same red as in 48-51?
Here's a picture of a 52 215 OHV 6 freshly painted with Alpine Green that Stu mentions. Lincoln green is probably much closer to the original color, but it is expensive. Last I checked it was arond $18 a can, while the Alpine Green was $6/can around here. The Alpine Green closely matches the stock intake manifold that still bore its original green paint.
Original intake still painted stock green color next to Alpine Green painted engine block.
Original color on right half. Alpine Green on left half.
Old 06-20-2012, 11:28 AM
sac52's Avatar
Thanks for the help guys.
Frame/suspension - black. not gloss, not matte, "just right"
Engine - red for 51, what about 52? red or green for the V8?
What about other parts? Under the cab, the firewall, the inner fenders, under the fenders, under the bed wood, the top of the bed wood, bumpers? Are all these things body color? I would guess bumpers and inner fenders are black?
Old 06-20-2012, 12:57 PM
Mercury Bluz's Avatar
Mercury Bluz Mercury Bluz is offline
Mercury Bluz is starting off with a positive reputation.
I not at home right now, so I don't a picture handy,but if you go to my gallery you will find a pic of my engine with the original colour. Duplicolor Detroit Diesel green is as close as your going get.
Luckily I found 6 rattle cans of it at a swap meet recently for a buck a can.
Old 09-13-2016, 02:46 PM
al.lug's Avatar
al.lug al.lug is offline
Al Lugtenburg
al.lug is starting off with a positive reputation.
1951 Ford F1 Frame and Engine Original Colors
Hi, I'm coming back to this post after four years to see if anyone can help me to match the original colors of a 1951 Ford F1 Truck frame/chassis and 8BA flathead engine and gear box.
Had to redo some work on my truck and want to match the exact original colors for frame, engine and gear box.
As far as I know the frame is painted black but I'm not sure if it's a bright or a matte black, or something in between. I think it's not bright but don't know how shiny it is. If someone have original frame pictures I'd like to see. Or any tips on what kind of black it is.
Flathead engines were red painted and I think the gear box was red too, but not totally sure about that. Same question here about the color, was it a shiny/bright red or a matte red? I was told it was a matte red but would like to see any picture of a original painted one to see if I can match it.
Many ghanks for any help!
Old 09-13-2016, 02:47 PM
al.lug's Avatar
Al Lugtenburg
Many THANKS for any help!!
Old 09-13-2016, 07:02 PM
KirkF KirkF is offline
KirkF is starting off with a positive reputation.
ENGINE ENAMEL-hirschauto.com
I think this is the colour you are looking for on the engine.
Kirk
Old 09-14-2016, 03:16 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Last I bought Detroit green was on my Napa shelf..
correct paint color for bench seat frame joezzz 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 08-15-2014 09:46 PM
Colors on a 52 Rimrock F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-03-2013 03:21 PM
correct paint colors for 1952 f1 Jpag52 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-15-2012 11:00 AM
To anyone that has put a SBC or SBF in a 1951-52 F-1 canadian_diesel1964 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 09-26-2010 09:56 PM
52 panel fuel tank location and frame info norvillebob 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 06-01-2010 07:14 PM
Tags
1952, color, colors, ford, motor, purple, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
