need help looking for a part
Old 06-19-2012, 08:41 AM
brockwood's Avatar
brockwood
brockwood is offline
It seemes that the line that runs from thr master cylinder to the slave cylinder on the clutch is rather hard to find.
This is for a 1960 f-100 w/three speed manual trans.
Can anyone direct me to a place that sells them new.
Thanks
Old 06-19-2012, 09:59 AM
manglass's Avatar
manglass
manglass is offline
I wasn't able to come up with much either. Perhaps NumberDummy will come up with a part number for a NOS piece.
You can probably make it out of steel brake tubing if there is no other alternative. Just be sure to make one or two loops about 3-4 inches in diameter in the area where the hose is now. This will absorb the vibration and keep the brake tubing from cracking. Look to 70's, 80's GM brake master cylinder lines for reference if you don't understand what I mean.
Lou Manglass
Old 06-19-2012, 03:24 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Brockwood, I came up with B7TZ-7A512-A for a part number, but a search found nothing.
If you have the old one? Any hydraulic hose shop could build one for you.
I found an old listing for an NOS that was 80.00 in 2007.
Good luck in your quest.
Old 06-19-2012, 03:31 PM
brockwood's Avatar
brockwood
Thank's for the replys
there is a hose place nearby they should be able to help.
Old 06-19-2012, 03:40 PM
manglass's Avatar
manglass
manglass is offline
I checked B7TZ-7A512-A:
Antique Auto Arlington Ford
ARLINGTON, TX 76015
817-275-2381
reports 2 in stock.
Lou Manglass
Old 06-19-2012, 10:29 PM
F250racer's Avatar
F250racer
F250racer is offline
I just made mine from metal brake line and it works fine.
Old 06-19-2012, 10:44 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
For my brake MC, line, which is very similar, I bought two standard ready made brake lines with fittings, and a hose with two female fittings to put in the middle. The brake tubes were really cheap from the rack at napa, and they ordered me the female-female hose and it came the next day. I think the hose was 9" long. But really, a couple of loops works on today's vehicles, so I'm guessing that's a lot cheaper........If it was my clutch, I'm sure I woulda gone with loops, but single master cyl.......I have lost brakes on two old trucks in my life and it is really, really scary! Oh and be careful if you look up 'female to female' on the 'net
Old 06-20-2012, 04:51 AM
Walston's Avatar
Walston
Walston is offline
I went to NAPA, we found a hose that was about the right length that is from a front wheel drum brake of some kind. Then we used short pieces of brake line on each end. IIRC we had one adapter fitting for the hose to get to the brake fitting thread.
Good luck
Old 06-25-2012, 10:31 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by manglass
B7TZ-7A512-A .. Tube-Clutch Master Cylinder to Slave Cylinder / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has 2 = 817-275-2381
CROSSETT FORD in Crossett AR has 1 = 870-364-9679.
No other Ford Dealer or obsolete parts vendor has any.
Old 06-25-2012, 07:11 PM
spurredon's Avatar
spurredon
spurredon is offline
For the most part, do rubber NOS parts maintain their integrity?
Old 06-26-2012, 04:33 AM
NumberDummy
Depends if the outer coating Ford used on rubber is still present or not. Rubbing ones fingers on it, removes it. But is this M/C to clutch S/C line made oughtta rubber?
Don't recall, and I haven't seen one in person since Carter was prez, parts catalog doesn't say. OP should call the sources and ask.
Old 06-26-2012, 06:42 AM
GB SISSON's Avatar
GB SISSON
It's a hard line at each end with a rubber brake hose swedged into the middle. So it's both......
Old 06-26-2012, 08:59 AM
lwclark's Avatar
lwclark
lwclark is offline
I've replaced both my brake and clutch lines with loops:
50fordhotrod
Large Truck
12-27-2015 02:23 PM
rocdril
12-20-2012 07:11 PM
twin58
04-07-2008 09:13 AM
Daveski
10-04-2006 04:10 PM
Narwhal
11-18-2003 07:45 AM
Quick Reply: need help looking for a part
