Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-19-2012, 08:41 AM
brockwood's Avatar
brockwood brockwood is offline
1960 Ford F-100
brockwood is starting off with a positive reputation.
need help looking for a part
It seemes that the line that runs from thr master cylinder to the slave cylinder on the clutch is rather hard to find.
This is for a 1960 f-100 w/three speed manual trans.
Can anyone direct me to a place that sells them new.
Thanks
  #2 (permalink)
Old 06-19-2012, 09:59 AM
manglass manglass is offline
Garage is empty, add now
manglass is gaining momentum as a positive member of FTE.
I wasn't able to come up with much either. Perhaps NumberDummy will come up with a part number for a NOS piece.
You can probably make it out of steel brake tubing if there is no other alternative. Just be sure to make one or two loops about 3-4 inches in diameter in the area where the hose is now. This will absorb the vibration and keep the brake tubing from cracking. Look to 70's, 80's GM brake master cylinder lines for reference if you don't understand what I mean.
Lou Manglass
  #3 (permalink)
Old 06-19-2012, 03:24 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is online now
theodore/teddy is gaining momentum as a positive member of FTE.
Brockwood, I came up with B7TZ-7A512-A for a part number, but a search found nothing.
If you have the old one? Any hydraulic hose shop could build one for you.
I found an old listing for an NOS that was 80.00 in 2007.
Good luck in your quest.
__________________
1959 F250 4x4
Wally
  #4 (permalink)
Old 06-19-2012, 03:31 PM
brockwood's Avatar
1960 Ford F-100
Thank's for the replys
there is a hose place nearby they should be able to help.
  #5 (permalink)
Old 06-19-2012, 03:40 PM
I checked B7TZ-7A512-A:
Antique Auto Arlington Ford
ARLINGTON, TX 76015
817-275-2381
reports 2 in stock.
Lou Manglass
  #6 (permalink)
Old 06-19-2012, 10:29 PM
F250racer's Avatar
F250racer F250racer is offline
F250racer is starting off with a positive reputation.
I just made mine from metal brake line and it works fine.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #7 (permalink)
Old 06-19-2012, 10:44 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
For my brake MC, line, which is very similar, I bought two standard ready made brake lines with fittings, and a hose with two female fittings to put in the middle. The brake tubes were really cheap from the rack at napa, and they ordered me the female-female hose and it came the next day. I think the hose was 9" long. But really, a couple of loops works on today's vehicles, so I'm guessing that's a lot cheaper........If it was my clutch, I'm sure I woulda gone with loops, but single master cyl.......I have lost brakes on two old trucks in my life and it is really, really scary! Oh and be careful if you look up 'female to female' on the 'net
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #8 (permalink)
Old 06-20-2012, 04:51 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
I went to NAPA, we found a hose that was about the right length that is from a front wheel drum brake of some kind. Then we used short pieces of brake line on each end. IIRC we had one adapter fitting for the hose to get to the brake fitting thread.
Good luck
__________________
Walston
http://bigjohnstractor.com/
  #9 (permalink)
Old 06-25-2012, 10:31 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by manglass View Post
B7TZ-7A512-A .. Tube-Clutch Master Cylinder to Slave Cylinder / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has 2 = 817-275-2381
CROSSETT FORD in Crossett AR has 1 = 870-364-9679.
No other Ford Dealer or obsolete parts vendor has any.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #10 (permalink)
Old 06-25-2012, 07:11 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
For the most part, do rubber NOS parts maintain their integrity?
  #11 (permalink)
Old 06-26-2012, 04:33 AM
Ford Parts Guru
2013 Ford Escape
Quote:
Depends if the outer coating Ford used on rubber is still present or not. Rubbing ones fingers on it, removes it. But is this M/C to clutch S/C line made oughtta rubber?
Don't recall, and I haven't seen one in person since Carter was prez, parts catalog doesn't say. OP should call the sources and ask.
__________________
  #12 (permalink)
Old 06-26-2012, 06:42 AM
GB SISSON's Avatar
It's a hard line at each end with a rubber brake hose swedged into the middle. So it's both......
__________________
  #13 (permalink)
Old 06-26-2012, 08:59 AM
lwclark's Avatar
lwclark lwclark is offline
1960 Ford F-100
lwclark is starting off with a positive reputation.
I've replaced both my brake and clutch lines with loops:
Click the image to open in full size.
__________________
Larry
1960 F100 Custom Cab Styleside
1966 MGB
I have no idea what I'm doing. May as well get started.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
