1955 Stock wheel size?
NumberDummy posted an answer to this in another thread
https://www.ford-trucks.com/forums/1...6-f-100-a.html
15" wheels were introduced, became standard equipment in 1955. From 1955 thru 1979, 16" wheels were optional.
But, no Ford truck until the 1990's came with 235/75/15 P-metric radial tires. Ford didn't offer radial tires for trucks until the 1970's, then only as an option. The original 15" tires for these trucks were bias ply blackwalls.
Innie = So called because the hubcap snaps onto tabs located on the inside of the wheels center section.
1965: Ford introduced "outie" 15" wheels for F100's, but innies were also available. Outie wheels became standard equipment in 1967, used thru 1996.
Outie = So called because the hubcap snaps over raised tabs located on the outside of the wheels center section.
btw: First US vehicle to come with radial tires as standard equipment: 1966 Oldsmobile Toronado with FWD (Front Wheel Drive), the first US car since 1937 to come with it.
Previous US cars with FWD: 1929 Ruxton, 1929/32 L-29 Cord and 1936/37 810/812/Beverly/Westchester Cord, called the "coffin nose Cord" the day it was first introduced, styled by Gordon Buehrig.
The Cord's styling became the most copied in the world. 1940/41 Hupp Skylarks & the 1941 Graham Hollywood used the Cord Westchester sedan body shells, but had RWD.
INNIE WHEELS!
6A-1130-A (replaced 6A-1130) .. Innie Hubcap ~ Blue Ford letters / Late 1947, 1948 Ford Passenger Cars / 1948/52 F1.
B3C-1130-A (replaced BAAA-1130-A) .. Innie Hubcap ~ Red Ford letters / 1953/56 F100.
The only difference between these two hubcaps is their letter colors.
The 6A hubcaps were still available from Ford in the 1970's, have now been reproduced. The B3C/BAAA hubcaps were obsoleted when LBJ was prez. Not reproduced AFAIK.
I'm not questioning Number Dummy's expertise, but, will only quote a couple facts I have come across.
On p.269 of Jim Wagner's book,"Ford Trucks Since 1905,"it states for 1956 (not 1955)," the formerly standard 6.00 x 16 wheel was made an option replaced by 15 x 5." Jim is a recognised authority on Ford Trucks.
Also, the Ford 1955 Shop Manuel lists 16" rims as standard and makes no mention of
15's.
15's.
Number, you are always a wealth if expert knowledge. But, just to be clear for stockers: another difference besides the color of the FORD letters is that the 48-52 hubcaps were stainless and teh 53-56 hubcaps were painted argent.
