How to straighten a bent hinge post? - Ford Truck Enthusiasts Forums
Old 06-18-2012, 11:26 PM
chintonmd chintonmd is offline
chintonmd is starting off with a positive reputation.
My 2001 F-150 Super Cab got the driver's door bashed in. It bent in the rocker panel and I'm working on that but the bad thing is that the bottom of the hinge post is bent inward about 1 inch (kicks the top of the door WAY out). If you draw a line from the top hinge through the bottom hinge it should be about vertical but this one obviously isn't. I bent it out some using a couple of come-alongs and then ran a 2x4 through the passenger door to the back side of the thing and hit it with a sledge hammer. Any better ideas?
I may just need to take it to the body man and have him put it on his frame machine. But, it cost me $2200 so I don't want to spend a lot getting it fixed. I could easily put a total of $5000 in this thing and it would still be a salvage truck. I could buy a good used one for less than that.
Old 04-01-2016, 10:01 AM
jhjr85 jhjr85 is offline
jhjr85 is starting off with a positive reputation.
Results
I know its been awhile, but do you remember how you solved this problem?
I have a similar issue now with a truck I just got. Guy who had it slid into a guard rail and now my drivers side (front and rear--Supercrew) doors have a big gap at top and lots of wind noise while driving!
I noticed that the bottom hinge is kicked in which is what I think is causing the issues.
Any suggestions of what to do to help straighten it back up? Thought about shimming it to make it line up better or somehow pulling the hinge to straighten out the pillar some
56 F-100 hood hinge trouble hooler1 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 09-03-2016 09:57 AM
Door wont seal correctly--bent door hinge jhjr85 1997 - 2003 F150 1 04-01-2016 02:51 PM
door hinge pin puller 48fordcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 05-21-2012 06:33 PM
Anybody familiar with 78 wing window? GruesomeJeans 1978 - 1996 Big Bronco 4 12-18-2011 03:43 PM
FAQ - Door hinge replacement that went well Roamer '80-'86 FAQs (Frequently Asked Questions) 7 05-08-2009 08:46 PM
Tags
bent, costs, door, f150, fixing, honge, passenger, repaint, rocker, straighten, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
