95 E150 gauges acting strange - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-18-2012, 05:22 PM
colour colour is offline
colour is starting off with a positive reputation.
95 E150 4.9 I noticed my coolant gauge fluctuating and abnormally high then I noticed my oil pressure really high. When I give it gas from a stop the oil gauge goes all the way up and the coolant gauge moves a quarter inch in either direction.
The charging and gas gauge seem to be normal, charging gauge may be slightly low.
Any clues
Old 06-19-2012, 03:33 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
first of all, econoline gages are notoriously inaccurate.
second, there is a component called the "instrument voltage regulator" mounted on the back of the instrument cluster, and when it fails, it usually causes the temp, oil, and fuel gages to all spike together. a problem with it WILL cause the 3 gages to make similar changes at the same time, usually in the form of excessively high readings.
you may also want to attach a voltmeter to the system to determine if your charging system is putting out too much voltage. the easiest way to set this up is to use a little guy like 12 Volt Battery/Alternator Tester , just plug it in and drive. i use mine all the time on various systems, its simple and reliable.
Old 06-19-2012, 07:37 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
He does not have a "instrument voltage regulator" mounted on the back of the instrument cluster in 1995.
Old 06-19-2012, 05:19 PM
Quote:
Ya I don't recall seeing anything attached to the back of the cluster but I do have a spare one I can swap.
Although my fuel gauge isn't acting erratic it may not be moving as much as it should.
I briefly checked the ground from the battery and that one seems to be fine. It does have the original alternator 170,000 miles. Dunno.
Old 06-19-2012, 07:36 PM
subford's Avatar
The ground to the body (10GA wire) from the NEG battery post is the one you to make sure is a good ground for the cluster.
Old 09-21-2013, 05:19 PM
moorefc moorefc is offline
moorefc is starting off with a positive reputation.
I found this post in a search. Same symptoms on my 95 E250. Found a couple of other posts on the internet with the same symptoms on E series. No answers, so......Turned out the ~4GA main engine/battery ground buried under the alternator was not tight. Cleaned it up and problems went away!
I spent a lot of time with wiring diagrams, other grounds and checking voltages but the main battery engine ground was the culprit. This ground is very hard to get at since it is buried back from the front right lower engine block corner......
Cheers
Old 09-21-2013, 05:44 PM
avenge avenge is offline
avenge is starting off with a positive reputation.
Reviving my old thread but strangely my problem disappeared when I replaced the starter which was struggling to turn over the engine when the engine was hot.
On a side note the starter lasted 17 years and was still working.
1972 Ford F-250 Interchangeable OEM gauges??? adamflow 1967 - 1972 F-100 & Larger F-Series Trucks 4 03-11-2016 12:14 PM
1995 E150 Replace Oil Pressure / Engine Coolant Gauges scottvan 1968-2013 Full Size Vans 1 08-04-2015 06:55 PM
69 f100 gas gauge and oil temp gauge not working gabestalker 1967 - 1972 F-100 & Larger F-Series Trucks 6 05-27-2014 01:46 AM
99 E150 Conversion Van Gauge Pod daghstdrummer 1968-2013 Full Size Vans 9 11-12-2013 07:27 PM
aftermarket oil pressure gauge problem 88grandmarquis 1987 - 1996 F150 & Larger F-Series Trucks 19 07-12-2011 09:58 PM
Tags
94, acting, e150, gauge, gauges, problem, temp, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
