leveling kit install, track bar bracket and retainer - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-21-2012, 10:55 AM
jshalala's Avatar
jshalala jshalala is offline
jshalala is starting off with a positive reputation.
Check this out also, found these Rancho Shocks on sale for 20 bucks each at Summit Racing. Picked up two for the front end last night. The stockers were rusted out really bad. Couldnt pass up that price
Here is a better pic of the truck leveled, I am really happy with how it looks. It sits even higher than I thought it would and that is awesome lol I just cant wait to drive it once I get that LAST STUPID bolt in lol
Old 06-21-2012, 06:27 PM
jshalala's Avatar
DONE!!!!!!!!!
Finally got it finished. I got home from work and didnt feel like beating on it or damaging the bolt so I took it around the block. Pulled over on the side of the road and the bolt had slipped right into place. WOOHOO. tightened it all down right there on the road. Drove it around for awhile then parked it and tightened down the ubolts.
FINALLY done with it lol
Now I have to install my new shocks.
Mount and balance the 315/75/16s I bought for the truck
Paint oil pan with por15
Coolant flush and change with ELC and install new waterpump and 203 tstat
Replace powersteering pump (sooner rather than later)
Replace cab corners and rear rockers.
Pull the bed and do the hutch/harpoon mods and replace/fix sending unit
Install Riffraff RR
Install WW, Banks exhust housing, non ebp pedestal and banks power elbow
2005 front end conversion
install PHP 6 position tuner
Install Glowshift 3 pillar pod gauges. (boost, egt, fuel pressure)
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
Old 06-25-2012, 07:56 AM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
What did you do to finally get the track bar bracket nut out of the frame rail. I crawled under my truck lastnight and found I have a broken bolt on the track bar bracket. I'm in a bit of a time crunch so I was just going to by a new nut/bolt if that ends up being easier. What was the trick?
Old 06-25-2012, 08:32 AM
jshalala's Avatar
Quote:
I just replied to your PM. Hope it helps. Lemme know if you have any other questions. What bolt is broken on yours. Front or rear?
Old 07-24-2013, 09:18 AM
jshalala's Avatar
I wanted to come back and post the part number for the track bar retainer bracket.
This is what fits inside of the frame rail and is what the track bar bolts into.
The part number is 2C3Z5C209-AA.
Reason being is that I am getting ready to lift another truck and was looking for the part number in case the bracket broke again on me lol
72 F-250 4X4 Power Steering - Instructions with Pictures tpdaniels 1967 - 1972 F-100 & Larger F-Series Trucks 23 03-01-2015 06:16 PM
Firestone Ride Rite 2330 No Drill Installation Writeup cowboybootlegger 1999 - 2003 7.3L Power Stroke Diesel 53 07-17-2012 12:43 PM
Build thread for "Fred" my 74 2wd Canus 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-10-2012 09:51 AM
'96 F-150 Front Recovery Points IJRoorda 1987 - 1996 F150 & Larger F-Series Trucks 5 11-04-2011 09:35 PM
DIY Winch Bumper MagKarl 1994.5 - 1997 7.3L Power Stroke Diesel 11 11-15-2009 12:19 AM
Tags
2002, axle, bar, bracket, drop, duty, f100, f250, ford, frame, kit, leveling, line, nut, powerstroke, remove, super, track
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
