1989 F-150, 300 6cyl Fuel pump and EEC power relays. - Ford Truck Enthusiasts Forums
Old 06-18-2012, 05:16 PM
SiscoKid SiscoKid is offline
SiscoKid is starting off with a positive reputation.
Question 1989 F-150, 300 6cyl Fuel pump and EEC power relays.
Hello all,
I had recently acquired a 1989 F-150, 300 6cyl 5 peed manual trans with 111,000 miles. It is a 4wd drive truck that is in fair shape. When i bought it this past winter, it ran great. As time went on, the engine started hesitating at around 1,800 to 2,000. After doing some trail and error repairs i still couldnt figure out what the problem was, so i called the previous owner. It turns out that he failed to inform me that the EEC power relay and the Fuel pump realy had been "rigged together" after the truck let him sit on the side of the road. So i went to the local parts store and bought brand new relays and connectors. I cut out the old connectors and tried putting in the new ones in. Upon doing so, the truck turned over but didnt fire leading me to believe that it is now not getting fuel. So the combination of a bad wiring job on behalf of the jackass that owned it before, and my inability to read a wiring schematic makes a very frustrating situation. Is thier anyone out there with a good picture of the way it should be done?
1989 F250 crank but no start Alex Wuerz 1987 - 1996 F150 & Larger F-Series Trucks 1 04-28-2016 10:34 AM
1989 F250 crank no start Alex Wuerz New Member Introductions 0 04-27-2016 06:25 PM
Key in Run Position, Fuel Pump Wont Turn Off HD 1987 - 1996 F150 & Larger F-Series Trucks 13 01-09-2016 08:05 AM
Back to the Drawing Board with my Fuel Pumps Building_Fords 1987 - 1996 F150 & Larger F-Series Trucks 0 11-28-2015 08:16 PM
No ground from fuel pump relay to ECM. SiscoKid 1987 - 1996 F150 & Larger F-Series Trucks 6 07-09-2012 09:54 PM
Tags
1986, 1989, 300, 89, cut, ecc, eec, f150, ford, injector, located, power, relay, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
