Exhaust Leak Help
Exhaust Leak Help
Hey guys. I bought my F250 with an exhaust leak. Didnt think much of it but now its just getting on my nerves. So I crawled under my running truck and found the problem: where my pipe attaches to my manifold isnt tight. Another problem: exhaust bolts = rusty bolts. I tried soakin it with some WD-40 but that didnt even touch the crud thats built up on these things! How do you fix this? There is in no way, shape, or form these things will wrench off of there. Are the studs press fit or threaded? Am I screwed?
Your manifolds sound exactly like the ones that were on my 1992 F350 w/5.8L engine. I was already committed to replacing the manifolds, but when I started to disassemble everything nothing snapped off.
WD-40 is a waste of time. Heat and something like PB Blaster are your best friend for this type of job. The studs are threaded into the manifold. By now they will most likely not come apart. I have drilled them out and used a bolt and nut before on previous vehicles. In cases like yours (and mine) it may make more sense to replace what you have. I elected to go with aftermarket replacement manifolds. If you have a larger budget consider headers, shorties or long tubes.
My '89 with a 5.8L is the same way. Priced it at Midas and they want $500.00+ to fix and was replacing everything between the manifold and the cat. A smaller shop said for less then $300.00 they can fix the problem by cutting off the flanges and removing the bolts and rewelding flanges on my exsisting pipe. They were also throwing in new hangers for free as the PO had my exhaust hanging by coat hangers thus causing my exhaust leak and for it to hang well below where it should. Most of the cost was labor for removing those bolts. My point is they said it's not a bad job to do if you have the correct tools, a little "know how", and a lift helps. I'm going with the smaller shop mostly because they will fix my hangers for free and I'd rather deal with an owner/operator then a chain.
My last duel system on my '03 Ram was $450.00. And that was only replacing the muffler and running duel pipes to the back. It still had stock exhaust from manifold up to the muffler. Pretty much going prices around here.
That was one of the reasons I bought a Gasless 110volt Mig welder in early 2000.It's a Cambell Hausfield 80 amp flux core wire Mig.It's easy to use(takes some practice),and I've done all my own exhaust systems,body panel replacements and all kinds of repairs for the past 12 years.Muffler shops will sell lenghts of pipe fairly priced.I pay 35.00(in the land of pay through the nose Canada) for 7 ft of 2 1/2 in and you can also buy mandrel bent turns.It allows you to get very creative.One of the best tools I've purchased,ever.
PB Blaster is your friend! Also, a number of people have mentioned heat. You can go anywhere from a propane torch, to a MAPP torch, to ocy-acetylene. I'm going to just keep soaking in PB Blaster until I can get a free weekend to start doing exploratory surgery. I did get a set of reverse-drill-and-easy-outs, along with the one that looks like a drill chuck just in case I get some snapping action. I'm steeling myself up for this job...
In the mean time, doses of PB Blaster every day is hopefully going to make this job less painful.
Thanks for the hint of removing the inner plastic fender bits. This is definitely easier as a ground up operation instead of top down.
lilmick21602
29
10-07-2014 10:10 PM
