BG Trans Fluid VS Mercon SP
Yep. It's been my experience that engineers, especially the ones who designed something, are the last people anyone wants to listen to. Where I work, engineers are assumed to be wrong until proven otherwise.
Somebody correct me or tell me if the trans places are blowing smoke. All the places that have a hot machine (I'm told). Have to use their bulk oil and put a magic additive that changes it to a synthetic. Asking if I supply the proper fluid can they use that to change it out? Their response was that it only hooked up to their bulk oil machine and they didn't know how to fill it with another oil.
I'm in the Detroit area and if anyone knows a place that can do the hot oil swap with the correct oil please let me know. The dealers around here seems to be going to this BG oil with the additive.
In the mean time did the fill and drain method and changed filters. By the way the dealer did not change either filters.
Sounds like a line of crap to me. You can't magically convert conventional oil to a synthetic with an additive. I would stay the hell away from that place.
Installed a spin on filter instead of the Magnafine that they had on there so I won't have to drop the pan that often.
Thanks again,
Dave
You are correct, Ford does not own the dealerships. The dealers, however, must run their business under the guidelines Ford gives them to follow. Its a franchise and there are very strict guidelines you must follow to continue to be a franchise of Ford. They signed a contract with Ford when they opened the doors and I can promise you it said very clearly something to the effect of "represent Ford in the manor we find fit at the time". I own a franchise in the food business and they are VERY SERIOUS about you upholding the image of their company. I am willing to bet Ford expects them to sell only Ford fluids in the dealership if for no other reason (coming from experience in food service) Ford wants to sell it to them and make more money. I would be willing to bet the head honchos at Ford don't know said dealership is selling fluids without the Ford brand name on it.
Check out this site. http://prayertr.ipower.com/swbgaz/media/Bg$20Universal$20Synthetic$20ATF$20Application$20C hart$5B1$5D.pdf
Use factory oil is a line Ford feeds you. There are only a few companies in the world that make base stock oil. But there are many that re-box. I have been using BG products as a Technician for 18 years. I can't think of a time that it has not outperformed a factory fluid. It is a full synthetic, it is less expensive and the only reason it wasn't compatible with LV when you first posted was politics. The manufacturers have a grace period that allows them to not license other brands for use in there vehicles, BG fluid was compatible with the LV fluid when it came out, it is just that they were not allowed to say so as it was not licensed with Ford. They have however been licensed since. This is a far superior fluid to ford LV. So I would not worry about it. Has worked great in All the fords I have used it on, with such success that customers have actually said that they have noticed and improvement in shifting and fuel mileage. Plus they back it up with the lifetime protection plan. Pay more for less if you like, that is up to you. Ford wants you to buy there fluid, that’s obvious.
What is LX oil? Never heard of it. When I try to go to the site you listed I get a not found error.
Ford does not say that you have to use their oil. Ford says that to maintain warranty coverage you must use either MERCON SP or MERCON LV fluid. They never say that you have to buy it from Ford.
You also made up that part about the grace period. That's pure fantasy.
Use factory oil is a line Ford feeds you. There are only a few companies in the world that make base stock oil. But there are many that re-box. I have been using BG products as a Technician for 18 years. I can't think of a time that it has not outperformed a factory fluid. It is a full synthetic, it is less expensive and the only reason it wasn't compatible with LX when you first posted was politics. The manufacturers have a grace period that allows them to not license other brands for use in there vehicles, BG fluid was compatible with the LX fluid when it came out, it is just that they were not allowed to say so as it was not licensed with Ford. They have however been licensed since. This is a far superior fluid to ford LX. So I would not worry about it. Has worked great in All the fords I have used it on, with such success that customers have actually said that they have noticed and improvement in shifting and fuel mileage. Plus they back it up with the lifetime protection plan. Pay more for less if you like, that is up to you. Ford wants you to buy there fluid, that’s obvious.
That is my experience, I'll stick with what works for me. The truck is too expensive to skimp on fluids.
#29
#30
"Ford does not say that you have to use their oil. Ford says that to maintain warranty coverage you must use either MERCON SP or MERCON LV fluid. They never say that you have to buy it from Ford.
You also made up that part about the grace period. That's pure fantasy."[/quote]
I just tried it again, this link works for me, or try: http://bglsi.com/312_GUIDE.pdf Or just google BG universal synthetic atf 312 application chart.
Sorry I meant LV Fluid, I edited my post to be the correct Letter. I only have experience. I am not a Lawyer, nor am I a politician. I have only heard of the "Grace Period" Through multiple different sources. It is similar to the release of information regarding repair information from the manufactures. The one that, as far as I understand, forces them to release information so as to not create a monopoly for dealers against independent shops. I have worked at dealerships before and have experience with the politics that the manufacturers are involved in.
However, if this is not the case of licensing, I stand corrected. It is just what I have been taught by many people my whole career. I certainly do not know everything, even after 20 years I am glad to still be learning every day. If I stop learning, I may as well quite.
As for the slipping back on hills, also have never had a complaint, but thanks for the information because as a technician it is important to here the odd situation out to become a better diagnostician. I will keep that in mind if I ever run into that situation.
