Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 06-17-2012, 11:02 PM
Fordmaster06's Avatar
Fordmaster06 Fordmaster06 is offline
Garage is empty, add now
Fordmaster06 is starting off with a positive reputation.
Shock mount
Anyone know where I can find a rear lower shock mount for a '60 F100? Mine broke.
  #2 (permalink)
Old 06-25-2012, 10:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
A stud passes thru the eye of the shock, then fits to a bracket mounted on the spring pack.
Which side do you need, right or left, is your truck 2WD or 4WD?
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 06-25-2012, 11:09 AM
Left side, 2wd. It looks like a bracket that attaches to the ubolts. The shock stud is molded to it, the left side stud broke so po turned it sideways and drilled a hole and bolted the shock to it. It doesn't fit right that way & it keeps coming loose.
  #4 (permalink)
Old 06-25-2012, 12:45 PM
Ford Parts Guru
2013 Ford Escape
1957/58 F100/250, 1959/60 F100/250 4WD: The stud & bracket were furnished individually.
> > 1959/60 F100/250 2WD: The stud is made as part of the mounting bracket. < <
B9C-18108-A .. Left (drivers) Side Rear Lower Shock Mounting Bracket and Stud Assy / Obsolete
No Ford Dealer or obsolete parts vendor has any.
I located 3 right sides (B9C-18109-A) NOS, but don't know if a right could be modified to work on the left. Let me know if interested.
__________________
  #5 (permalink)
Old 06-25-2012, 01:09 PM
That's ok, thank you for looking! I'm sure I can fabricate something. I can weld and fabricate some stuff, if not my dad is a certified welder and claims he can "weld anything from a broken heart to the crack of dawn"
  #6 (permalink)
Old 06-25-2012, 01:39 PM
Ford Parts Guru
2013 Ford Escape
Can he weld the temperature in Arid-Zone-A so it doesn't get over 90 (during the day) in summer? I was in Phoenix once when the daytime high was 118. By midnight, it had dropped to a "cool" 99!
__________________
  #7 (permalink)
Old 06-25-2012, 01:58 PM
I'm an AZ native, I'd take the heat anyway over the cold. I love summertime! The winters are unbearable, gets down into the 40's. I wear 3 layers of clothes to work!
  #8 (permalink)
Old 06-25-2012, 07:28 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Sounds like the heat has gotten to you over the years, 40 degrees is just about perfect for doing any real physical activity! After a run of below zero temps, 40 feels like summer! It is 58 degrees tonite and it is great T-shirt weather!
We all get use to different things!
  #9 (permalink)
Old 06-25-2012, 10:02 PM
gtilton.as gtilton.as is offline
1960 Ford F-350
gtilton.as is starting off with a positive reputation.
At 40 degrees in January i'll be out in the yard in a tee shirt. When it hits 90 i grab a beer and a chair, cause my day is done.
Tags
1960, f100, shocks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
