Dakota speed sensor for 1951 Ford F1
Old 05-17-2021, 11:44 AM
Eric1109's Avatar
Eric1109
Eric1109 is offline
Thank you all that helped with my questions for temp and oil sensors with Dakota gauge.
Seems I have a question regarding speed sensor. Dakota gauge came with a sensor and adapter. Not sure if I need adapter. I have included picture of my sensor port on tranny and fittings provided by Dakota. Should I undo the fitting on my transmission and put both Dakota pieces together and into tranny. Or just screw the fitting that has connection for wires into tranny. No explanation as to why I would use adaptor.
Old 05-17-2021, 03:50 PM
moejr's Avatar
moejr
moejr is online now
Received 1,016 Likes on 480 Posts
My guess it needs that adapter to function properly with the sender.... the one you have might not "match up"??
Old 05-17-2021, 06:32 PM
schoo's Avatar
schoo
schoo is offline
I would give Dakota a call they have helped me with a call.
Are you running a non electronic engine?
Old 05-17-2021, 06:38 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,450 Likes on 1,397 Posts
Will your sensor (the part on the left) fit onto the threaded stub on the transmission? The part on the right is typically found on the end of the speedo cable that fits a C4, C6, etc. The driven gear fits onto the end of the adapter and then goes into the transmission. I don't believe it will fit in the old truck trans. If the sensor fits on the trans, as is, that should be all you need.
The following users liked this post:
GhostComanche
2017+ Super Duty
17
02-25-2021 12:01 PM
4x4pwr
Modular V10 (6.8l)
06-07-2016 12:05 AM
bwiday
1999 to 2016 Super Duty
03-24-2012 09:59 AM
cpettymore7777
04-20-2011 07:32 AM
emict
09-22-2010 09:56 PM
Quick Reply: Dakota speed sensor for 1951 Ford F1
