Precision Metal Fab RSK
  #76
Old 06-07-2014, 04:31 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Craigslist or the local junkyard. I found my set by just calling the junkyard a few times until they had a truck with the springs still on them. If the springs are pulled off the vehicle, there's no good way to know which spring code you're getting since the code is on the driver's door sticker.
  #77
Old 06-07-2014, 04:40 PM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
Thank you sir.
  #78
Old 06-07-2014, 06:07 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by Crewcabber
Where's the best place to find the SD springs
I buy my springs New and from Ford
  #79
Old 06-07-2014, 06:19 PM
Crewcabber's Avatar
Crewcabber
That would be the best place. I didn't know if Deaver or Atlas made a better spring.
  #80
Old 08-14-2015, 05:12 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
BROWN DOG KTM is offline
Old thread resurrected
I've looked thru evr pic & hadn't seen one of rear shackle angle with this RSK & superduty springs ....... ?
I installed a ORU RSK 7yrs ago with stock 96 2leaf springs & my rear shackles were strait up & down.
I jus put 6" Skyjacker springs in & my shackles are leaned forward at bottom 2.5" because springs are SHORTER eye to eye.
Arched springs gets longer as suspension compresses & they CAN'T with the weight of the truck pushing upwards on a forward leaning rear shackle.
It fighting itself .
I hope I'm explaining this properly ?
Today I'm changing to 6" lift 99-04 Superduty longer springs to get the shackles a little rearward like all the spring companies recommend for better ride.
I know I'm gna have to move axle forward to center the tire in the fender BUT I'm NOT moving my frt bracket forward or changing my bracket.
IF I moved my frt brkt 3+ inches forward, my rear shackles wldnt be leaning rearwards with the longer superduty springs.
Any thoughts ?
  #81
Old 08-14-2015, 12:34 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Brown Dog KTM started another thread HERE about this.
  #82
Old 10-03-2015, 12:11 PM
Pork_Chop50's Avatar
Pork_Chop50
Pork_Chop50 is offline
Sorry for dragging up an old thread but after reading through this I have just a few questions for clarification. I have a set of U code '03 SD front springs that I want to swap into my '94 F-350 CC. I will be using the PMF RSK kit with a 2.25" lift.
Will I need to change both my pitman arm and track bar bracket with this kit to accommodate the increased height?
Brad mentioned using the rear sway bar connecting rods up front to maintain proper function. Is that correct or did I misread that?
Also I have poly bushings in my current OBS springs, will they swap over to the SD springs or will I need to get some different bushings specific to the new springs?
Lastly thanks to those who detailed their work doing this. It is greatly appreciated.
  #83
Old 10-03-2015, 04:55 PM
Diesel_Brad
Will I need to change both my pitman arm and track bar bracket with this kit to accommodate the increased height? neither, i am running STOCK pitman arm and track bar mount. BUT I am running an adjustable track bar
Brad mentioned using the rear sway bar connecting rods up front to maintain proper function. Is that correct or did I misread that?YES, you read that correctly
Also I have poly bushings in my current OBS springs, will they swap over to the SD springs or will I need to get some different bushings specific to the new springs? Spring bushing are different OBS to SD
You are welcome
  #84
Old 10-03-2015, 06:24 PM
Pork_Chop50
Thanks Brad for the quick response. Final track bar question. Is your adjustable track bar longer than stock? As in will I need to either go with a drop bracket or adjustable bar to maintain proper function?
  #85
Old 10-03-2015, 07:51 PM
Diesel_Brad
Yes. longer than stock.
You would want a adjustable bar, a drop bracket shoves the mount back and then it hits the sway bar
  #86
Old 10-03-2015, 09:26 PM
BROWN DOG KTM
Yes go adj track bar as its the only true way to CENTER your axle.
I use a plumb Bob hanging from fenders on a string to know when tires are dead center
I've got a lightly used drop pitman arm if Interested :
  #87
Old 10-05-2015, 09:07 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
My experience is that the track bar drop should be the same amount of pitman arm drop.
If no track bar drop, then no pitman arm drop.
But if you do either, make sure it is it he correct amount. A 3" drop pitman arms isn't always 3" drop. Don't dwell on this unless you are going to do one or the other.
  #88
Old 12-05-2018, 10:00 PM
97F450DRW4x4's Avatar
97F450DRW4x4
97F450DRW4x4 is offline
Bumping RSK thread...
I just purchased 2.25" RSK for my 97' f350 4x4 7.3psd...going with SD front springs and possibly "U" codes after talking to Brad
will post some pick when kit arrives
  #89
Old 12-05-2018, 10:17 PM
BROWN DOG KTM
I too am running RSK : ORU I think it was years ago, with 99-04 Super Duty Leafs to get the proper rear shackle lean angle.
my frt suspension actually works now & isn’t fighting frt truck weight when trying to compress the leaf springs
  #90
Old 12-06-2018, 05:06 AM
Diesel_Brad
I cleaned out my PMs
Quick Reply: Precision Metal Fab RSK
