My 1st on I installed in my 96 F350 CCLB. I uses S code front springs and B code rear springs.
Originally Posted by Diesel_Brad
I am using U code(4800lbs) springs for my 460 truck
and V code(5200lbs) in my diesel.
The 460 weighs about 200lbs less than the diesel
Diesel_Brad, you've got a lot of trucks and I don't always keep them straight in your posts, but did you change from the S code to the U code in your '96? How's the ride compare among the S, U, and V code springs? Do you think there's a big difference in weight on the front of a crew cab 460 truck vs a regular cab 460?
How much lift (or not) do each of the springs alone provide?
In my 460 truck I just went w U codes(4800lbs). The reason being is the 460 is almost 200lbs less than the powerstroke and the V code(5200lbs) is the choice for them.
The crewcabs have quite a bit more front axle weight than a reg cab. I know when add-a-leafs are sold for a crew cab, they put 2 leafs PER pack in the front. A reg cab only get one leaf.
For a reg cab I would be looking at a T code (4400lb)
As for height difference, I dont think there is much till you go to an X code(snow plow prep 6000lb)
I've been doing some research into both CT Peformance's & PMF's RSKs. Which do you prefer and why? It sounds like Cary has an updated RSK which doesn't require cutting a welding or a bumper trim like the original, but it costs quite a bit more than PMF's RSK. I'm talking to Cary now on options and pricing, but I want a third party opinion from somebody who's used both.
I like the PMF RSK as it is a bolt in piece that did not mean removing the rear hanger. I am happy to see that SKY reworked the kit not require bumper cutting etc to used SD springs.
I haven't gotten details yet, but this is from an email I received from Cary today on the rear hanger:
...with rear front spring frame mounts for better shackle angle, made for SD springs...
Is there a need for this? It seems Cary is the go to guy for these swaps, so I assume he should know. I'll ask in my next email to him.
I will also add that PMF was good to work with on getting my kit customized. I kind have a mix and match setup with the RSK from PMF and most of the rest of the parts from Cary.
Has anyone seen this kit on an '87-'91? I'm ok with drilling holes, but I don't like cutting stuff. Is it confirmed that it'll work with the bricknoses?
Also, does anyone have a part number for U code front springs? And B code rear springs? The B code rears are the optimal choice, right? I've got an '89 CCLB with the 460.
Looking at the pics, I wonder if you could get away with just using the outside frame mounts? I'm no structural engineer, but I think not having the inside two bolts would be ok.
