The winterbeater build thread
Well to start the truck is a 1979 F.250 4x4. My dad got it last winter to drive and after driving it for a little bit the 400m in it decided to die. So we parked it out back the garage and havent thought about it for a while. So I decided that since I`m gonna need a winter truck that I might as well use it. I tore the motor out and found a pretty well totaled crankshaft. I decided to try to get a 460 for it but about a $1,000 to put a motor back in a beater truck was too much. So after tossing around the idea of a 302, instead I decided to rebuild the 400. Here are a couple pics of the truck.
The trucks body is pretty rough here and there but not too bad in my mind and for a beater what the heck. Heres the major bad spots in it. The bed is the worst thing on the truck. It doesn`t have any roof rot in it though.
Also while I was at a swap meet today I found a recently turned crank, new main and rod bearings, piston rings and on top of that a new oil pump for $40. So hopefully I can get the 400 rebuilt pretty soon and for not too much money.
Well I took the motor down to the machine shop on Monday and they put in new cam bearings and cleaned the block up. The cam ended up being a piece of junk. So I am going to have to get a new one and was wondering what would be a good cam for it. It`s only a winterbeater but I`d like it to have some power. Any ideas?
Those both look like pretty good cams. I found an RV style cam from them I think I`m gonna get.
I was looking at the intake manifold I have which came off this motor and i was wondering if it is too much for this 400? It is a 4bbl Holley Dominator intake manifold. If I could I`d like to run this 400 with the Holley Dominator intake manifold and a 600 cfm Edelbrock Carburetor and a set of long tube headers. Do you all think this combination will work out alright or should I get a stock 4bbl 400m intake manifold?
Also is the 600cfm carbeurator a good size? When I tore this motor apart it had a 780 double pumper carbeurator and it ran like a piece of crap.
AD with a Holley Dominator: HOLLEY STREET DOMINATOR ALUMINUM INTAKE MANIFOLD FORD 351M-400M | eBay
Any idea what the operating range for this intake manifold is?
Also has anyone ran one and experienced how well they run?
No factory 4v manifolds for 351m/400...
Also I got an update. I got the motor back. The shop I took it to had a 1 day turn around time. It cost me $173 to have the block honed, freeze plugs removed and the new cam bearings with installation. I think that`s pretty good for a machine shop?
I got to looking at the motor block yesterday and ran into a snafu. When the machine shop planed the surface deck of the motor block they took out the dowel pins which help locate the heads on it. Any ideas as to where I could buy new ones, because the old ones are too twisted up to be used again?
Well I had another failure with this motor. I went to put the crankshaft and new bearings in. It all went together really well until I went to plastiguage it and found out that my crankshaft is cut .010 under, but the bearings are STD size bearings. That set me back $140 from Summit. So if anyone is looking for a set of brand new STD crankshaft bearings, (mains and rods) pm me. I`ll sell them dirt cheap.
Also I got to putting the rear main seal in and found a crack in the motor block. It is right on the rear main seals edge and goes down about a 1/2 inch. Its like someone was trying to knock the old seal out and accidentally hit the block instead. Do you think it will leak or should I just put some RTV silicone in there and put it together?
Heres a pic of it
Heres a pic of it
