86 F250 wheels won't fit new rotors (Fixed!)
You guys are awesome,thanks again for all your input.
Ford says E7TH-1102-CA and the change up YC3Z-1v102-CA are now obsolete.They got a part # via application and are shipping them tomorrow......hope they're right, will keep you posted.
And yes Rouge,the wheels are lug centered with tapered nuts
If truck modified by FoMoCo (as original purchaser requested something that was not an RPO) between the time it left the assembly line and arrived at dealership, it would be a Domestic Special Order and have a 6 digit DSO code.
Domestic Special Order parts are not (usually) listed in parts catalogs, dealer contacts Ford, passes along the DSO. Ford looks up the order number (last 4 digits of DSO), then tells the dealer where the special parts could be obtained.
6 digit DSO also applies to special paint, there would be no color code(s) on the Warranty Plate/Certification Label. Same scenario applies, dealer needs paint formula(s), contacts FoMoCo w/6 digit DSO.
Some 1983/89 F250's came with 8.8" rear axles. Ford never called 'em light duties, but that's exactly what they were. Sterling 10.25 rear axle intro'd 1985.
Bootlegger's Deluxe
07-06-2013 07:33 AM
mustanginca
02-02-2008 04:29 PM
